soomanyquestions
Detect Internet feature does not work on RB3011
Wed Aug 07, 2019 9:25 pm
I have two RB3011's and the detect internet feature works on only one of them. I have reset the configuration to the defaults on both of them and only turned on the detect internet feature.
They both have the same version of RouterOS and same exact configuration. I have tested both of them with the same internet connection (literally using the same cable).
Does anyone know how to solve this problem or has anyone faced the same problem?
Thanks.
victorsoares
Re: Detect Internet feature does not work on RB3011
Wed Aug 07, 2019 10:35 pm
I honestly don't care much for this feature, never had any luck with it. I know that there is a post here somewhere and they explained how they define if there is internet connection or not. I just turned this off on my routers.
soomanyquestions
Sun Aug 11, 2019 1:32 pm
Yeah, It is a quite useless feature when it dosent even work consistently.
What are you using for detecting internet for failover scenarios?
