MUM Europe 2020
machack
Problem ICMP/TRACEROUTE CRS317-1G-16S+
Fri Aug 09, 2019 1:59 am
Problem With CRS-317-1G-16S + (SWOS 2.9)!!!
Since we installed a CRS-317 we have a problem, every trace route that passes through it does not show the jumps.
Example from a Router connected to our provider directly, all jumps are viewed correctly.
Issue:
If we make a trace from the router (a) to 8.8.8.8 (internet) connected as explained below, the trace only shows the destination 8.8.8.8 (see image)
router (a) CCR-1036-8G-2S <-----> CRS-317 <------> (b) CCR-1036-8G-2S <----> Provider (intrernet)
More details:
The switch CRS-317 has in automatic MODE 2 cables DAC reaching Negotiation of 10G in both router. Ping in both directions works OK, speedtest works perfect more than 8Gbps between both routers, there are no FILTER / NAT / MANGLE firewall rules that can interfere.
If you can give me an idea of where the problem is, I thank you.
Cesar Javier Robles
www.WindNet.com.ar
MTCNA - MTCTCE - MTCRE - MTCWE
EdPa
Re: Problem ICMP/TRACEROUTE CRS317-1G-16S+
Fri Aug 09, 2019 9:24 am
Thank you for the provided details.
The switch does not forward the ICMP TTL exceeded and it appeared in SwOS 2.9 version. We look forward to fixing this in upcoming SwOS versions. As a workaround, you could try to use RouterOS instead.
kosyot
Re: Problem ICMP/TRACEROUTE CRS317-1G-16S+  [SOLVED]
Fri Aug 09, 2019 10:11 am
There are lot known bugs on SwOS 2.8 and 2.9, especially for CRS317, and we waiting more than 8 months MikroTik fo fix it.... Keep your switch to SwOS 2.7 to avoid problems.
Check there is a lot of topics about this.
machack
Fri Aug 09, 2019 3:59 pm
Thanks, where i can download SwOS 2.8 for CCR 317? and i hope work.
Cesar Javier Robles
www.WindNet.com.ar
machack
Fri Aug 09, 2019 4:00 pm
Thanks, when can you fix these? if i downgrade to SwOS 2.8, i fix these?
Cesar Javier Robles
www.WindNet.com.ar
machack
Fri Aug 09, 2019 5:07 pm
Yes Iam downgrade to 2.8 like tell @kosyot and work!!!!
i hope Mikrotik fix these!
Cesar Javier Robles
www.WindNet.com.ar
elmemis
Tue Sep 03, 2019 6:49 am
Javier, contactate con soporte que ya está disponible la versión 2.10. A mi me la pasaron por email (les reporte este mismo error) y según ellos corrige este este error. Mañana lo confirmaré.
Saludos.
machack
Wed Sep 04, 2019 1:08 am
Saludos.
Muchas Gracias
Cesar Javier Robles
www.WindNet.com.ar
Users browsing this forum: No registered users and 107 guests
