MichalP
gsm, error allowed number does not match with: ???
Mon Aug 12, 2019 3:55 pm
I am trying to receive sms with RBSXTR v6.45.3
Sometimes smses are comming to inbox, sometimes not and in logs I can see following error:
gsm,error allowed number does not match with: +4853246xxxx
gsm,error allowed number does not match with: +4853889xxxx
gsm,error allowed number does not match with: +4857097xxxx
gsm,error allowed number does not match with: +4853919xxxx
gsm,error allowed number does not match with: +4872886xxxx
I didn't set anything in "allowed-number:" field. It should allow all numbers by default as I understand...
after print it, it is showing some comas:
> tool sms print
           status: running
  receive-enabled: yes
             port: lte1
          channel: 0
           secret:
   allowed-number: ,,,,
       auto-erase: no
          sim-pin:
        last-ussd:
How to solve it to receive all sms'es
robpeng
Re: gsm, error allowed number does not match with: ???
Mon Aug 12, 2019 4:28 pm
I had the same issue
I send sms's to my SXT to run scripts, this changed in 6.43/6.45, I had to add my number to the 'allowed-number'
After setting my number in the 'allowed-number' section, I could not see my number there, I am guessing this is for security reasons
MichalP
Mon Aug 12, 2019 4:47 pm
It works very randomly.. sms'es from many number are comming to inbox, from some another numbers are not coming :(
My goal is to know where what numbers I have in multiple devices. So I need to receive smses from all numbers.
Then by api I am logging to one RBSXTR that is receiving all smses and exporting all data from there to excel.
Unfortunatelly with this error all my approach is failure.
@Mikrotik please comment what is the logic behind it. Is it an error and you will fix it? or it is a feature :D
baronkis
Sat Sep 14, 2019 12:53 am
I have same problem.
Users browsing this forum: No registered users and 53 guests
