dragorasche
POE current-too-low
Mon Aug 12, 2019 6:45 pm
I purchased a Hex PoE and tried to connect my Aruba IAP-305 Access-Point.
The IAP-305 supports both Standards (.af/.at) and works well with a cheap POE-Injector (.at)
But on the Hex PoE it doesn't work. I got "current-too-low" but I think it should work with the default 24V 2.5A Supply.
any ideas?
thanks
andriys
Re: POE current-too-low
Mon Aug 12, 2019 11:37 pm
af/at requires at least 48V to function correctly, so you need to buy a proper PSU separately. The standard 24V PSU is only suitable for Passive PoE. More info in the official product brochure: https://i.mt.lv/cdn/rb_files/hEX__poe-190722120922.pdf.
Users browsing this forum: No registered users and 15 guests
