MUM Europe 2020
remcovm
CRS317-1G-16S+RM SFP+ routerOS issue
Thu Aug 15, 2019 11:44 am
Hi all,
hope you can help me shed some light on this. I recently got this box as the first Mikrotik I've owned. Eager to try it out I plugged in some intel 10GSR SFP+ (FTLX8571D3BCV-IT) modules, which swOS instantly recognised and negotiated a link at 10Gbps - iperf tests show that indeed I'm getting a 10G link through the switch. Nice.
However, if I boot the box into routerOS, no link. Only when I switch off auto negotiation, and force the link speed to 10,100 or 1000 Mbps I get a 1Gbps connection (even though routerOS claims it's either 10,100 or 1000). Forcing the interface speed to 10G or anything else results in no link. The optics get recognised just fine:
                        name: sfp-sfpplus3                                                              sfp-sfpplus4
                      status: no-link        no-link
            auto-negotiation: done        done
                 advertising:
    link-partner-advertising:
          sfp-module-present: yes        yes
                 sfp-rx-loss: no        no
                sfp-tx-fault: no        no
                    sfp-type: SFP-or-SFP+                                                               SFP-or-SFP+
          sfp-connector-type: LC        LC
        sfp-link-length-50um: 80m        80m
        sfp-link-length-62um: 30m        30m
             sfp-vendor-name: Intel Corp        Intel Corp
      sfp-vendor-part-number: FTLX8571D3BCV-IT                                                          FTLX8571D3BCV-IT
         sfp-vendor-revision: A        A
           sfp-vendor-serial: AH60D4E        AH60D5Z
      sfp-manufacturing-date: 10-02-08        10-02-08
              sfp-wavelength: 850nm        850nm
             sfp-temperature: 35C        36C
          sfp-supply-voltage: 3.303V        3.299V
         sfp-tx-bias-current: 5mA        5mA
                sfp-tx-power: -4.54dBm        -4.516dBm
                sfp-rx-power: -3.597dBm        -5.668dBm
             eeprom-checksum: good        good
Both swOS and routerOS are the latest stable releases (2.9 and 6.45.3 respectively). Any suggestions on how to fix this or is this a routerOS bug?
Remco
bearxm
Re: CRS317-1G-16S+RM SFP+ routerOS issue
Tue Aug 20, 2019 1:20 pm
I am experiencing the same problem
Users browsing this forum: No registered users and 19 guests
