MUM Europe 2020
Snite
CCR1009 temperature sensor issue
Sat Aug 17, 2019 11:10 pm
Hello!
I have an issue with a temp sensor in my new CCR1009-7G-1C-1S+.
I am collecting values over SNMP every 1 minute, and almost every time received value is correct (28-31C)
But sometimes i can see a spikes over 80C, every few hours.
That spikes occur in random times, not related to CPU load.
Does somebody here have similar issue?
Is it issue of CCR1009? or maybe caused by firmware (6.44.5)?
or just my device has a some hardware defect?
mada3k
Re: CCR1009 temperature sensor issue
Mon Aug 19, 2019 10:32 pm
We also have noticed this behaviour on a couple of CCR1009s.
Manages some CCR's, RB750Gr3, RB922 and wAP's
Elans
Tue Aug 20, 2019 7:39 am
On which exact CCR1009 model you have noticed such CPU behavior (if possible, provide SN)? We will try to reproduce it locally.
madox
Tue Aug 20, 2019 4:43 pm
+1 from me also.
First i bought ccr1009PC and everything was fine with temp log. Then i moved to 1009+PC and temp checking script from time to time alarms about high temp but in health status everything was normal (i had a little script to check temp and sends email if it is getting too hot).
After months of sporadically false alarms i stoped the script.
Snite
Tue Aug 20, 2019 7:51 pm
Model: CCR1009-7G-1C-1S+
S/n: 914F0A7AC1B0
some data collected from device:
Users browsing this forum: npero and 52 guests
