patrickmkt
PowerBox Pro not powering with POE in
Mon Aug 19, 2019 12:47 pm
I just received a new PowerBox Pro this morning. I can power it through the power jack without problem, however, when I plug eth1 into a POE switch (even with a short cable), the Powerbox Pro does not power on.
Is there a hidden setting somewhere that I need to change to accept 802.3af for POE in?
Or did I get a faulty unit?
normis
Re: PowerBox Pro not powering with POE in
Mon Aug 19, 2019 12:54 pm
Your switch is most likely not Passive PoE, but 802.3af/at. This device must receive Passive PoE:
PoE in Passive PoE
PoE in input Voltage 12-57 V
patrickmkt
Mon Aug 19, 2019 9:24 pm
Then you would need to revise the brochure as it is clearly stated:
"It also supports passive or standard 802.3at/af PoE input/output."
That was for me the main interest of the Powerbox Pro compared to the standard one (in addition to the sfp).
krafg
Forum Veteran
Forum Veteran
Tue Aug 20, 2019 12:22 am
I power on my PowerBox pro using Passive PoE IN (Power Supply + PoE Injector) and works OK. I no have any PoE switch to do the test.
Regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
troffasky
Fri Feb 05, 2021 7:40 pm
I guess they never got around to fixing the brochure, https://i.mt.lv/cdn/product_files/PowerBox_200318.pdf still says this today.
Users browsing this forum: No registered users and 44 guests
