cavaughan
Discord question
Wed Aug 21, 2019 9:49 pm
Got a question about blocking a computer. On the MK router I have the computer use a static IP and in the firewall I can choose to drop all traffic for that computer. It works for everything except the messaging program Discord. As long as it is open it maintains a connection. HOW?
Curtis Vaughan
Seattle, USA
Sob
Re: Discord question
Wed Aug 21, 2019 10:48 pm
It sounds like you don't drop everything, but only new connections. Rules are processed in order from top to bottom, so if you'd have standard "accept established & related" before you drop rule, it would allow existing connections to survive.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
cavaughan
Wed Aug 21, 2019 11:19 pm
Here are the 1st four rules. The rule to block the computer in question is rule No. 3 (counting from 0 - 3), which I put on Drop for Action when wishing to terminate all internet activity. So would I have to basically disable the first rule (as the other 2 are to permit VPN connectivity), then enable Drop for Rule 3, then re-enable Rules 1?
Curtis Vaughan
Seattle, USA
Sob
Thu Aug 22, 2019 12:08 am
No. It's not exactly as I thought. The first one is not real rule, you can't disable it. But it shows that you have fasttrack enabled and I don't know if there's a way to close fasttracked connection. One way would be to permanently disable the whole thing, but it's useful, so it's not the best solution.
Edit: One thing you can try is blocking in raw table, but I'm still not sure if fasttrack bypasses that too or not.
cavaughan
Thu Aug 22, 2019 12:19 am
Blocking in raw table? What is that?
Curtis Vaughan
Seattle, USA
Sob
Thu Aug 22, 2019 12:55 am
IP->Firewall->Raw, it's similar to IP->Firewall->Filter. Just use prerouting chain instead of forward. But remember, maybe it won't work either.
cifzo
Thu Aug 22, 2019 2:36 am
Could you use a script to knock down all the existing connections for that IP?
viewtopic.php?t=137245
sebastia
Thu Aug 22, 2019 11:25 am
hey, list your fill firewall rule set, for both ipv4 & ipv6.
what I'm wondering: you have fasttrack dummy rule, but not fast track itself..., view is incomplete
fasttrack will bypass most of ip processing for bigger part of packets of a connection, but on regular basis packets will be processed with full path (to refresh connection tracking stats)-> if it's blocked then, connection will be terminated.
also fasttrack will no bypass raw, as it's based on connection tracking, which is established after raw filtering
Users browsing this forum: Google Feedfetcher, mcmurdyy, meletis, nemke, sindy and 94 guests
