ratamann
SFP transceivers Rx and Tx power
Thu Aug 22, 2019 5:47 pm
Hi, I have doubts about the Rx power of a 7Km link with these tranceivers S-35/53LC20D two module kit
i would like to know if i haver a good values of Rx power, i attach the images thanks
https://imgur.com/a/BV5m1y1
https://imgur.com/a/RiPkTnv
msatter
Re: SFP transceivers Rx and Tx power
Thu Aug 22, 2019 8:28 pm
Here you cwn find the brochure and see if you are at the max. and normally you should be lower than the max.
https://i.mt.lv/cdn/rb_files/SFP2-131002143606.pdf
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.20 / MikroTik APP 1.3.4
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Users browsing this forum: No registered users and 15 guests
