WojtusW5
CRS326-24S+2Q+RM - 40G passive connection with Huawei
Fri Aug 23, 2019 5:15 pm
Hello, I have a problem with connecting CRS326-24S + 2Q + RM with Huawei S6720-54C-EI-48S-AC switch. The connection is made using a MikroTik Q+DA0001 40GBPS QSFP+ cable.
Both devices can see the passive cable correctly. Interestingly, when 2 ports of the same device are connected (MikroTik and Huawei) through the MikroTik passive cable, the ports are rising.
Has anyone had a similar problem ?
Thank you in advance for your help.
I invite you to visit my blog
https://mikrotikon.pl/
Guntis
Re: CRS326-24S+2Q+RM - 40G passive connection with Huawei
Wed Aug 28, 2019 3:52 pm
What did you mean by "when 2 ports of the same device are connected (MikroTik and Huawei) through the MikroTik passive cable, the ports are rising." ?
WojtusW5
Wed Aug 28, 2019 8:34 pm
If I connect 2 ports 40G with a MikroTik passive cable on a Huawei switch (making a theoretical loop) the ports are up.
If I connect 2 ports 40G with a MikroTik passive cable on a MikroTik CRS 326 switch (making a theoretical loop) the ports are up.
If I connect using the same cable Huawei to MikroTik ports remain down.
Guntis
Fri Aug 30, 2019 8:44 am
Please send us email about this at support@mikrotik.com
lix5027
Wed Sep 04, 2019 7:23 am
Yes, I have the same problem.
When I used qsfp-qsfp DAC cable, the Huawei port is down, the CRS328 port is down.
ros version is 6.45.5 6.46.b38
lix5027
Wed Sep 04, 2019 7:41 am
good news!
you should disable HW switch "negotiation",enable CRS326 auto negotiation.
then the 40G port is up!
In CRS , It will show qsfp1 up (2,3,4 down), but you can see the qsfp1 port speed is 40G.
Users browsing this forum: No registered users and 22 guests
