MUM Europe 2020
jtde
EoIP no RX on main side of the bridge
Mon Aug 26, 2019 1:50 pm
Hi there, I hope you've had a good start to the new week.
I need to bridge two networks together and I think EoIP is the easiest way to do so - MPLS would be much more complicated. In the GNS3 lab the EoIP configuration worked great, but on the production system one side of the tunnel doesn't receive packets. The other side can send and receive.
Remote side, looks ok:
Main side, no RX!
The remote address of the main side is the same as the bridge address, so I can't assign an IP address from this network to the remote office side's bridge and I can't do any diagnosis on the remote office's MikroTik except inspecting the traffic. Torch on the remote side (that can send and receive) shows traffic from the main side.
This is the (simplified, but very close to production) setup that works in GNS3:
Any idea goes wrong with the main side, not receiving any packets?
Thank you,
Josef
Exiver
Re: EoIP no RX on main side of the bridge
Mon Aug 26, 2019 2:47 pm
Without seeing your configuration no one can really tell you whats wrong here ;-)
jtde
Mon Aug 26, 2019 5:09 pm
I'm not sure which part of the configuration is relevant... please tell me if I'm missing some information.
Main Router
/interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1_provider1                         ether            1500  1596       2026 CC:2D:E0:XX:XX:Y1
 1     ether2_provider2                         ether            1500  1596       2026 CC:2D:E0:XX:XX:Y2
 2  RS ether3_lan                          ether            1500  1596       2026 CC:2D:E0:XX:XX:Y3
 3     ether4                              ether            1500  1596       2026 CC:2D:E0:XX:XX:Y4
 4     ether5                              ether            1500  1596       2026 CC:2D:E0:XX:XX:Y5
 5  R  bridge_lan                          bridge           1380  1596            CC:2D:E0:XX:XX:Y3
 6  RS eoip-wle2ed                         eoip             1380 65535            00:00:5E:80:00:01
/interface bridge print
 0 R name="bridge_lan" mtu=auto actual-mtu=1380 l2mtu=1596 arp=enabled arp-timeout=auto
     mac-address=CC:2D:E0:XX:XX:Y3 protocol-mode=rstp fast-forward=no igmp-snooping=no auto-mac=yes
     ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6
     vlan-filtering=no dhcp-snooping=no
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE               BRIDGE               HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     ether3_lan              bridge_lan           yes    1     0x80         10                 10       none
 1     eoip-wle2ed             bridge_lan                  1     0x80         10                 10       none
/ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.178.3/24   192.168.178.0   ether1_provider1
 1   192.168.2.3/24     192.168.2.0     ether2_provider2
 2   192.168.30.2/24    192.168.30.0    bridge_lan
 3   192.168.30.15/24   192.168.30.0    bridge_lan
 4   192.168.30.1/24    192.168.30.0    bridge_lan
/interface eoip print
 0  R name="eoip-wle2ed" mtu=auto actual-mtu=1380 l2mtu=65535 mac-address=00:00:5E:80:00:01 arp=enabled
      arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s
      loop-protect-disable-time=5m local-address=192.168.30.15 remote-address=10.14.100.81 tunnel-id=5
      keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no allow-fast-path=yes
/ip ipsec policy print where dst-address=10.14.100.0/24
Flags: T - template, X - disabled, D - dynamic, I - invalid, A - active, * - default
 #     PEER  TUN SRC-ADDRESS                                    DST-ADDRESS
 0  A  ;;; bSH side
       ;;; peer not set
             yes 192.168.30.0/24                                10.14.100.0/24
/ping 10.14.100.81 interface=bridge_lan
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 10.14.100.81                               56  62 20ms
    1 10.14.100.81                               56  62 19ms
Remote Router:
/interface print
 0  R  ether1                              ether            1500  1598       2028 74:4D:28:XX:XX:Y1
 1  XS ether2                              ether            1500  1598       2028 74:4D:28:XX:XX:Y2
 2  XS ether3                              ether            1500  1598       2028 74:4D:28:XX:XX:Y3
 3  RS ether4                              ether            1500  1598       2028 74:4D:28:XX:XX:Y4
 4     pwr-line1                           ether            1500  1598       2028 74:4D:28:XX:XX:Y5
 5  XS wlan1                               wlan             1500  1600       2290 74:4D:28:XX:XX:Y6
 6  R  ;;; defconf
       bridge                              bridge           1500  1598            74:4D:28:XX:XX:Y2
 7  R  bridge_lan                          bridge           1500  1598            74:4D:28:XX:XX:Y4
 8  R  eoip-ed2wle                         eoip             1458 65535            00:00:5E:80:00:02
/ip address print
 0 X ;;; defconf
     192.168.29.1/29    192.168.29.0    bridge
 1   10.14.100.81/24    10.14.100.0     ether1
 0  R name="eoip-ed2wle" mtu=auto actual-mtu=1458 l2mtu=65535 mac-address=00:00:5E:80:00:02 arp=enabled
      loop-protect-disable-time=5m local-address=10.14.100.81 remote-address=192.168.30.15 tunnel-id=5
/ping 192.168.30.15
    0 192.168.30.15                              56  62 20ms
    1 192.168.30.15                              56  62 19ms
Bridge interface packet statistics:
eoip-wle2ed: 77140 Tx, 0 Rx
eoip-ed2wle: 5735 Tx, 74884 Rx
IPANetEngineer
Trainer
Trainer
Mon Aug 26, 2019 5:17 pm
You have an MTU Mismatch and it appears to be inheriting it from the bridge. You need to get the MTUs to match even if you have to lower the whole segment MTU
192.168.30.15
actual-mtu=1380
10.14.100.81
actual-mtu=1458
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
jtde
Mon Aug 26, 2019 10:42 pm
True! I realised that and I expected some fragmentation and higher CPU load, but not a situation where one of the both sides can't receive data from the other. In my lab, the MTUs do mismatch and it works.
One hour ago I synchronized the MTU of the EoIP interface, but not of the bridges. Now the main side still can't receive packets from the remote side. One bridge no longer matches the MTU of its EoIP interface. Is that a problem?
192.168.30.15
bridge_lan mtu=auto actual-mtu=1380 l2mtu=1596
eoip-wle2ed" mtu=1380 actual-mtu=1380 l2mtu=65535
10.14.100.81
bridge_lan mtu=auto actual-mtu=1500 l2mtu=1598
eoip-ed2wle mtu=1380 actual-mtu=1380 l2mtu=65535
Thank you very much.
Exiver
Mon Aug 26, 2019 11:33 pm
Im not 100percent sure but on one router (main device) you are using 192.168.30.15 as local address while this address is bound to the bridge you are binding the eoip tunnel to. Sounds logical wrong to me - can you try to set this local address to your main routers wan address? If that doesnt work please paste the output of /export hide-sensitive since we dont know which firewall / bridge firewall rules you have set (and much other stuff which could interfere here)
Users browsing this forum: No registered users and 24 guests
