muetzekoeln
ROS7: Requests for wireless features
Mon Aug 26, 2019 5:52 pm
Let's collect all feature requests (for ROS 7) regarding wireless in this thread.
Starting with an extended version of an existing request my me:
- dot11k/r/v based roaming / AP steering in CAPsManager; viewtopic.php?t=86271&start=50
- dot11k/r/v based band steering (also without CAPsManager); viewtopic.php?t=127742
- option for airtime fairness; viewtopic.php?t=118354#p625975
- support of wave2 (MU-MIMO, beamforming); viewtopic.php?t=145047
- tunable DTIM and beacon interval; viewtopic.php?t=116221
- stop broadcasting device model and ROS version with the beacon; viewtopic.php?t=133186
- support dot11d including country code; viewtopic.php?t=72840; viewtopic.php?t=144151
- support of TPC on DFS channels; viewtopic.php?t=112515&start=100#p559837
- allow for longer group-key-update in WPA properties; viewtopic.php?t=68782#p509666
- support "zero wait DFS"; viewtopic.php?t=123762#p704167
- add option "dfs-mode" for use with superchannel setting to enable DFS at will; viewtopic.php?f=1&t=45934&p=728151&hilit=FCC#p728151
WeWiNet
Re: wireless feature requests
Mon Aug 26, 2019 6:49 pm
Two issues:
1.) ROS6 wireless package does everyting: CPE, AP mode, NV2, long distance outdoor etc., P2P, P2MP and so on
Hard to support all this with all the new features together you ask for (and sometimes they are exclusive)
2.) Most of the features you mention will only apply / be useful to the AP's, and then also only to AP's with 4 or 8 streams/antennas.
MU-MIMO, Beam forming etc. Today there is only RB4011 which has 4 streams and could really benefit form all those features.
Mtik should bring out more 4x4 solutions to use those features efficiently and also tri band solutions to be able to use
distributed Wifi (as the earlier presented Audience product).
I also would like to see
- MESH / SON (Self organising network) funcitons with automatic backhaul selection
- Band steering (to me more important that ATF)!
WeWiNet
MTCNA
hapac2, map, hap-lite, ltap-mini, RB4011 :-) !!!
muetzekoeln
Tue Aug 27, 2019 6:58 pm
add
- 802.11w support; viewtopic.php?t=108923
- EAP-PWD (RFC5931) support; viewtopic.php?t=129518#p726274
Jotne
Re: Wireless feature requests ROS 7.0
Tue Aug 27, 2019 8:08 pm
You should edit the header of the post to:
So its easy to see that it has to do with v7.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
mistry7
Re: ROS7: Requests for wireless features
Tue Aug 27, 2019 8:42 pm
You missed
Spektral Scan
mfr476
Tue Aug 27, 2019 10:19 pm
I expect a miracle!
mistry7
Thu Aug 29, 2019 9:02 am
After the last 5 years with 802.11ac we expect nothing
mkx
Thu Aug 29, 2019 9:24 am
I expect a miracle!
You know the timeline: we deliver the impossible immediately, for miracles you have to wait for a while ;-)
BR,
Metod
Users browsing this forum: No registered users and 80 guests
