emils
Forum Veteran
Forum Veteran
v6.45.5 [stable] is released!
Wed Aug 28, 2019 2:29 pm
RouterOS version 6.45.5 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.45.5 (2019-Aug-26 10:56):
Important note!!!
Due to removal of compatibility with old version passwords in this version, downgrading to any version prior to v6.43 (v6.42.12 and older) will clear all user passwords and allow password-less authentication. Please secure your router after downgrading.
Old API authentication method will also no longer work, see documentation for new login procedure:
https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
Changes in this release:
*) crs328 - adjust fan speed based on SFP and CPU temperature;
*) dhcpv4-server - fixed "Acct-Output-Octets" reporting to RADIUS;
*) health - improved fan control on CRS3xx and CCR1016-12S-1S+r2;
*) ike2 - don't release policy on rekey when child not found;
*) ike2 - fixed ID validation with multiple SAN;
*) ike2 - fixed policy port selection for responder with natted initiator;
*) ike2 - fixed traffic selector address family selection when using IPv6;
*) ike2 - improved rekeying process with Windows initiators;
*) ike2 - properly start all initiators to the same remote address;
*) ipsec - allow inline "passphrase" parameter when importing keys;
*) ipsec - fixed "eap-radius" authentication method (introduced in v6.45);
*) ipsec - fixed minor spelling mistakes in logs;
*) lte - fixed cell information monitoring on R11e-LTE-US (introduced in v6.45.2);
*) lte - fixed LTE interface disappearing on RBSXTLTE3-7;
*) smb - improved stability on x86 and CHR (CVE-2019-16160);
*) snmp - fixed encrypted data sequence (introduced in v6.44.5);
*) ssh - fixed carriage return presence in subsequent sessions;
*) switch - fix port isolation for non-CRS series switch chips;
*) system - accept only valid string for "name" parameter in "disk" menu (CVE-2019-15055);
*) upnp - fixed XML parsing (FG-VD-19-110);
*) watchdog - renamed "no-ping-delay" parameter to "ping-start-after-boot";
*) winbox - added "auto-erase" parameter to "Tools/SMS" menu;
*) winbox - added "https-redirect" parameter to "IP/Hotspot/Profiles menu";
*) winbox - added "revision" parameter to "System/Routerboard" menu;
*) winbox - removed "max-sms" parameter from "Tools/SMS" menu;
*) wireless - fixed basic rate reporting in snooper;
What's new in 6.45.4 (2019-Aug-13 09:04):
(factory only release)
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
alibloke
Re: v6.45.5 [stable] is released!
Wed Aug 28, 2019 3:36 pm
After reboot my fan speed dropped slowly down to zero. Temperatures are climbing up from ~40 degrees previously (and ~2900rpm fan speed):
/system health> print
         temperature: 49C
     cpu-temperature: 54C
   power-consumption: 41.7W
  board-temperature1: 36C
        psu1-voltage: 26.4V
        psu2-voltage: 52.6V
        psu1-current: 0.3A
        psu2-current: 0.6A
          fan1-speed: 0RPM
          fan2-speed: 0RPM
*EDIT
Things seems to have stabilised now:
         temperature: 56C
     cpu-temperature: 58C
   power-consumption: 42.2W
  board-temperature1: 41C
        psu1-voltage: 26.4V
        psu2-voltage: 52.7V
        psu1-current: 0.3A
        psu2-current: 0.6A
          fan1-speed: 495RPM
          fan2-speed: 390RPM
Chupaka
Wed Aug 28, 2019 5:21 pm
Guys, when making a topic with new version released, please post a link in previous topic (that is been closed) so that people receive notifications...
HZsolt
Wed Aug 28, 2019 5:37 pm
Topic of previous (6.45.3) version: viewtopic.php?f=21&t=150767
ErfanDL
Wed Aug 28, 2019 7:32 pm
I have problem by 6.45.5 with wifi on RB951Ui. The clients connection is not stable and connection lost
Sent from my SM-A705FN using Tapatalk
Jotne
Wed Aug 28, 2019 9:25 pm
This does not help.
Someone needs to make a post in previous version with a link to this new version so that people who subscribe to previous version, see that a new version is released. Then its ok to close old release.
elbob2002
Wed Aug 28, 2019 9:33 pm
Yes indeed. I should have known better than to upgrade. Edit: This is a CRS328-24P-4S+
k6ccc
Thu Aug 29, 2019 2:37 am
I note that both alibloke and the chart that elbob2002 posted show the temperature stabilized at 58 degrees C. Makes me think that is what it is designed to do. I don't know what the specs for the CPU chips involved are, but as a comparison, the Raspberry Pi does not start throttling to control heat until it gets to 80 degrees C. Based solely on that comparison, 60 C is not bad...
Yea, we would all like to have our CPU chips cold to the touch, but that's not realistic.
Chupaka
Thu Aug 29, 2019 7:53 am
This does not help.
Correct. Something like this: viewtopic.php?p=747274#p747274
ofer
Thu Aug 29, 2019 9:53 am
Upgraded HapACx3 6.45.3 => 6.45.5 no special issues, all is good.
bda
Thu Aug 29, 2019 2:31 pm
Sorry, but are any news on bug with "GRE marking as invalid pakets" in this release?
JanezFord
Thu Aug 29, 2019 2:42 pm
Tried upgrading hAP from 6.45.1 to 6.45.5. Result: Not enough space for upgrade!
JF.
notToNew
Thu Aug 29, 2019 2:59 pm
There is no bug. It just got fixes some Versions ago.
sindy
Thu Aug 29, 2019 3:03 pm
"The accuracy of your information could be sucessfully questioned". You are right that the bug consisting in having the firewall too open for GRE was fixed, but bundled with this fix came another bug - the very first GRE packet of a new tunnel is improperly labelled with connection-state=invalid.
nichky
Thu Aug 29, 2019 3:20 pm
what for?
Frostbyte
Thu Aug 29, 2019 3:51 pm
On the topic of CRS328:
Since there are always going to be conflicting opinions between people who require a quieter experience and don't mind it running hotter (but still within spec) than usual and people who don't mind the noise and prefer running them cooler.. Why not finally offer options to set things manually and everyone can be happy? (relevant thread)
ErfanDL
Thu Aug 29, 2019 3:54 pm
Sunlight
Thu Aug 29, 2019 4:04 pm
Not fixed in this release: viewtopic.php?f=2&t=151456
LeftyTs
Thu Aug 29, 2019 4:10 pm
+1000 in other fan controlable MT devices as well this would be a really nice feature to add
docmarius
Thu Aug 29, 2019 9:07 pm
The bug preventing multicast RIP announcements over IPIP tunnels in 6.45.3 is solved. Not in the changelog, but anyway, tnx...
Jotne
Thu Aug 29, 2019 9:19 pm
On my hAP lite, I had to delete all backup files and other files from the flash folder to be able to upgrade. Så this may be your problem as well.
danieltecnet
Location: https://www.google.com.br/maps/@-4.9872 ... 128006,16z
Thu Aug 29, 2019 9:50 pm
I would like to know what is going on with the CCR1036? because after a while after updates etc .. they lock from nothing even with cooling and low use of cpu the equipment simply crashes and if someone doubts put one like BPG / OSPF or PPPOE and will see who in about 30 days use it will crash out of nowhere. and we have several in the network about 4 months ago we did not have these problems and only happens with the 1036 2s + I'm already until I have to exchange the pppoes servers that eran mikrotik 1036 for cisco huawei and other things that do not crash without explanation and have scalability since mikrotik does nothing but a 1072
bda
Fri Aug 30, 2019 1:12 am
Sure! This bug still present... Too bad...
Caci99
Fri Aug 30, 2019 2:46 pm
It is not a bug. This has being long discussed in 6.45.1 release. The behavior of GRE now is related to CVE-2014-8160.
Read the 6.45.1 topic and you'll find solutions on how to get your GRE up and running. What Mikrotik can do though, is to automatically add filter rules in firewall once one sets up a gre tunnel, or any tunnel dependent on gre.
w0lt
Long time Member
Long time Member
Fri Aug 30, 2019 5:40 pm
Where is the procedure detailed on how firewall rules are automatically created?
-tp
Caci99
Fri Aug 30, 2019 8:28 pm
-tp
I didn't say it exists, I said they can implement it.
eddieb
Fri Aug 30, 2019 8:47 pm
updating to 6.45.5 went smooth ... from 6.45.3 to 6.45.5 with some help from the dude ;-)
No problems so far
RavenWing71
Fri Aug 30, 2019 9:12 pm
Web-Proxy Access Redirect is still failing to redirect. Reverting to 6.44.5 corrects the problem. See Ticket#2019082422001346 for more details.
manojlovicl
Sat Aug 31, 2019 1:37 am
I have two routers that are doing BGP (they are made redundant by using VRRP ...) Since update on 6.45.5 IPv6 static routes are simply ignored and after BGP becomes stable (after rebooting that was needed for update) I was forced to change gateway to some dummy IP on all static routes in my routing table to make it work again. So basically it seems like it does ignores static routes on boot. Disabling and re-enabling the static route does not help. As I said - I was forced to change gateways on both routes for those specific static routes to make them work again.
Luka
meazz1
Sat Aug 31, 2019 5:35 pm
Upgraded my hex mmips from 64.45.3 to 6.45.5, no upgrade issue and everything seems good. My setup is just basic out of the box for my home use.
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Sat Aug 31, 2019 8:12 pm
Upgraded Hap AC2 to 6.45.5 and getting ssh auth messages in log I did not get before
14:39:22 ssh,info auth timeout
14:39:23 ssh,info auth timeout
14:45:45 ssh,info auth timeout
14:46:37 ssh,info auth timeout
14:53:13 ssh,info auth timeout
14:56:28 ssh,info auth timeout
15:06:41 ssh,info auth timeout
15:19:12 ssh,info auth timeout
15:25:40 ssh,info auth timeout
15:29:21 ssh,info auth timeout
15:32:58 ssh,info auth timeout
15:36:42 ssh,info auth timeout
15:36:43 ssh,info auth timeout
15:48:42 ssh,info auth timeout
15:55:21 ssh,info auth timeout
15:58:41 ssh,info auth timeout
16:02:24 ssh,info auth timeout
16:06:11 ssh,info auth timeout
16:10:05 ssh,info auth timeout
16:25:56 ssh,info auth timeout
16:38:51 ssh,info auth timeout
16:38:52 ssh,info auth timeout
16:42:40 ssh,info auth timeout
17:04:57 ssh,info auth timeout
17:14:34 ssh,info auth timeout
17:27:29 ssh,info auth timeout
17:30:41 ssh,info auth timeout
18:10:24 ssh,info auth timeout
18:20:01 ssh,info auth timeout
18:36:07 ssh,info auth timeout
18:42:37 ssh,info auth timeout
18:44:51 ssh,info auth timeout
18:49:08 ssh,info auth timeout
19:05:08 ssh,info auth timeout
anav
Sat Aug 31, 2019 9:34 pm
Do you mean, messages you should have been getting and now are getting.........good! or
extra invalid messages......... bad :-(
CZFan
Sat Aug 31, 2019 10:27 pm
To add info to above, this device has been connected to internet for more than a year, first time these messages came up is after upgrade, hence I thought reporting it.
I am getting login failures also in logs, but surely the "bad guys" did not only discover my device now after a year and only trying to access it now?
Maybe RoS is only starting to report these properly now, dont know, maybe I got a "Known bad IP" from PPPoE when I restarted after upgrade, dont know...
Restarted PPPoE to get new IP, nothing so far, will monitor
Jotne
Sun Sep 01, 2019 8:25 am
But do you have SSH to your router wide open on public internet????
heyandyhey
Sun Sep 01, 2019 2:55 pm
Hi all, first post but long time forum lurker... I'm struggling to get this update on my RouterBOARD 941-2nD hAP lite
Current version 6.45.2 to 6.45.5
Error not enough disk space 7.3MiB required and only 7.3iMiB is free
I've cleared out all the files and rebooted
[admin@R1] > /file print
# NAME TYPE SIZE CREATION-TIME
[admin@R1] >
admin@R1] > /system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-smips 6.45.2
1 system 6.45.2
2 X ipv6 6.45.2
3 wireless 6.45.2
4 X hotspot 6.45.2
5 mpls 6.45.2
6 routing 6.45.2
7 ppp 6.45.2
8 dhcp 6.45.2
9 security 6.45.2
10 advanced-tools 6.45.2
Could anyone help? Ive not had a problem updating in the past using winbox
soohoe
Sun Sep 01, 2019 3:54 pm
[admin@R1] >
Flags: X - disabled
1 system 6.45.2
2 X ipv6 6.45.2
3 wireless 6.45.2
4 X hotspot 6.45.2
5 mpls 6.45.2
6 routing 6.45.2
7 ppp 6.45.2
8 dhcp 6.45.2
9 security 6.45.2
Maybe can give this a try: https://blog.pessoft.com/2019/03/02/mik ... sk-device/.
Same device with same error.
mkx
Sun Sep 01, 2019 4:28 pm
[admin@R1] >
Flags: X - disabled
1 system 6.45.2
2 X ipv6 6.45.2
3 wireless 6.45.2
4 X hotspot 6.45.2
5 mpls 6.45.2
6 routing 6.45.2
7 ppp 6.45.2
8 dhcp 6.45.2
9 security 6.45.2
Good article. Only ... SOHO users almost definitely don't need routing package, that one is needed for advanced routing protocols such as BGP or OSPF ... simple routing (with a few static routes with some default gateway) is performed by system.
CZFan
Sun Sep 01, 2019 9:41 pm
Further to above, the upgrade seems to have broken my firewall, all rules that had in-interface-list specified, changed to "unknown", and when you open the rule, it says in-interface-list=all
Didzito
Mon Sep 02, 2019 11:13 am
Hi, After upgrade to 6.45.5 my BGP connections start going to idle state and renews only after enable/disable or some time. They drops each 10mins - 2 hours.
Configuration ir ipsec/over gre and bgp.
I revert all routers to 6.45.3. all works. 6.45.4 didnt mentioned this problem too, but there was RADIUS issue.
Kazek
Mon Sep 02, 2019 1:50 pm
I'm not sure if this problem was already mentioned at this forum but I had already few times a problem where after upgrading (ccr) to newest Os - bridges changed the mac address and they have exactly the same ones = conflict and the whole network goes bat crazy.
I know using Admin MAC would avoid this but there should be some kind of security against that by default.
Elans
Tue Sep 03, 2019 8:09 am
There is no particular reason to do so, since device must be cooled down when it becomes hot. There are various reasons why this feature has not been implemented yet, although, as I have said in the thread you have mentioned - we are planning to add some basic fan control, however, currently we are unable to tell You when such changes could be available.
annc
Wed Sep 04, 2019 7:07 pm
"Tried upgrading hAP from 6.45.1 to 6.45.5. Result: Not enough space for upgrade!"
+1, never ending story.....
irobot
Thu Sep 05, 2019 12:10 am
UPDATE:
tried the following way
but it didn't work. Files have been uploaded using Files menu in the root folder. After restart nothing happened. Version remains the same.
UPDATE2 (Problem SOLVED):
dhcp package was missing.
router has 6.45.5
hello
can't update my hap lite from 6.45.3 to 6.45.5:
ERROR: not enough disk space, 7.3MiB is required and only 7.3MiB is free
I have no scripts or anything like this. Just stock firmware updated regularly.
How can I proceed with the upgrade?
Thank you!
Jotne
Thu Sep 05, 2019 8:36 am
Not tested, but may work.
Downgrade to an older or upgrade to beta image that is a smaller image than you currently have installed, then upgrade to 6.45.5, or wait for 6.46 that looks to be smaller.
List of SMIPS version and the size of them.
Version   bytes
6.46.38b  7445921
6.45.5    7689899
6.45.4    7722659
6.45.3    7722646
6.45.2    7808734
6.45.1    7767691
6.45      7767663
6.44.5    7702189
6.43.16   7672934
6.42.12   7533422
Problem is that 6.45.x are the largest image for the SMIPS devices. When did upgrade to it, you did barely have space to do so. Then when you try to upgrade from one 6.45 to another 6.45, you have two larger image..
So by changing to an smaller image, you may be able to upgrade to a larger image later.
Doing so, my give you problem with your configuration, so have both a full backup and a readable backup file of you config.
DenisPDA
Fri Sep 06, 2019 12:10 pm
viewtopic.php?f=19&t=151903
RouterOS v7 beta
http://mt.lv/v7
Only for hap ac2, wap ac
Maxke
Fri Sep 06, 2019 3:38 pm
I used my SPF port as WAN but after the upgrade it doesn't work anymore.
If I use the default eht1 it works fine.
Even using the spf as brige for LAN doesn't work.
Anybody an idea ?
Thx
Ataker
Sat Sep 07, 2019 9:59 pm
Hotspot does not redirect to login page in hap lite. Its working normally on release 6.44.5.
Multik
Mon Sep 09, 2019 7:28 pm
Can't add script:
I have a script for upload resources to my web service. After insert text and click OK - Winbox is disconnect. And that same result when insert MD5 calculation script (find on somewhere in forum).
Its a simple script for fetch tool
Code: Select all
/system script run "MD5"
:global StrToMd5
:local secureKey "ddddd"
:local architectureName [/system resource get architecture-name]
:local boardName [/system resource get board-name]
:local version [/system resource get version]
:local badBlocks [/system resource get bad-blocks]
:local factorySoftware [/system resource get factory-software]
:local identity [/system identity get name]
:local model [/system routerboard get model]
:local serialNumber [/system routerboard get serial-number]
:local firmwareType [/system routerboard get firmware-type]
:local factoryFirmware [/system routerboard get factory-firmware]
:local currentFirmware [/system routerboard get current-firmware]
:local upgradeFirmware [/system routerboard get upgrade-firmware]
:local httpData ("architectureName=".$architectureName."&boardName=".$boardName."&version=".$version."&badBlocks=".$badBlocks."&identity=".$identity."&serialNumber=".$serialNumber."&model=".$model."&firmwareType=".$firmwareType."&factoryFirmware=".$factoryFirmware."&currentFirmware=".$currentFirmware."&upgradeFirmware=".$upgradeFirmware."&factorySoftware=".$factorySoftware)
:local hash [ :pick [ $StrToMd5 ($httpData."&hash=".$secureKey) ] 1 ]
/tool fetch url="https://mysite?hash=$hash" mode=https keep-result=no http-data=$httpData http-method=put
plankanater
Tue Sep 10, 2019 5:02 am
Had to add an accept gre firewall rule at the very top to get tunnels to establish and use packets bigger then 1458.
DanielT
Tue Sep 10, 2019 3:21 pm
YAY!! HTTPS redirect, YAY!!
Thanks Mikrotik... only 2 years late - but better late than never, right ;-)
Works a charm,
Thank you!
XaTTa6bl4
Tue Sep 10, 2019 5:10 pm
I think in your cases there is not enough memory for the cache:
6.45.1
*) proxy - increased minimal free RAM that can not be used for proxy services;
I've just found the same problem on my test hap lite. Setting, for example,
/ip proxy set max-cache-object-size=1KiB
- resolves issue
spacemind
Tue Sep 10, 2019 5:29 pm
IP Cloud not working in 6.45.5 or 6.46beta38.
keeps updating and does not work.
[X] /ip cloud> print
ddns-enabled: yes
ddns-update-interval: none
update-time: yes
status: updating...
osc86
Wed Sep 11, 2019 8:57 am
ddns-enabled: yes
update-time: yes
status: updating...
[CORE] > ip cloud pr
ddns-enabled: yes
update-time: yes
public-address: X.X:X.X
public-address-ipv6: X:X:X:X:X:X:X:X
dns-name: xxxxxxxxx.sn.mynetname.net
status: updated
[CORE] > sys rou pr
routerboard: yes
model: CCR1009-7G-1C-1S+
serial-number: XXXXXXXXXX
firmware-type: tilegx
factory-firmware: 3.33
current-firmware: 6.45.5
upgrade-firmware: 6.45.5
working fine here, check dns and output filter rules
emils
Forum Veteran
Forum Veteran
Wed Sep 11, 2019 1:28 pm
New version 6.45.6 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=152033
Users browsing this forum: No registered users and 4 guests
