stephenbravo
APs Dropping all connections frequently
Fri Aug 30, 2019 9:24 am
I'm using CAPsMAN from my PoE switch (CRS328-24P-4S+) and all my APs will disconnect all devices simultaneously sometimes. The timing varies, but I've had from 2 days between occurrences to 1 hour between occurrences.
APs are CAP AC.
I have 4 SSIDs setup, 2 using a password, 1 open and hidden, and 1 using MSCHAPv2.
I normally have between 10 and 20 devices connected at any given time.
I've tried:
Disconnecting all but one AP to see if there's interference
Changing provisioning action from create dynamic enabled to create enabled
Monitoring CPU and Memory usage, to see if there's a spike at the time of disconnections (there isn't)
Using different cables to connect the APs
Users browsing this forum: No registered users and 20 guests
