sjoram
Secondary Channel
Sat Aug 31, 2019 5:46 pm
Forgive my ignorance on this, but I assume the secondary channel option relates to the ability to have 2 channels running for 160MHz, or am I misunderstanding?
The hAP ac2 doesn't support this seemingly - do any of the other similar models support this?
mkx
Re: Secondary Channel
Sat Aug 31, 2019 6:01 pm
AFAIK only RB4011 (wireless version) supports (non-contigous) 80+80 MHz ... it's been explained that for contigous 160MHz channel one doesn't need to set secondary channel.
Capsman is different beast and secondary-channel setting is used differently.
PackElend
Sat Aug 21, 2021 5:26 pm
could you elaborate more details on how this setting is used differently by CAPsMAN?
mkx
Sat Aug 21, 2021 8:08 pm
In CAPsMAN, /capsman channel section, the property name is extension-channel, which takes the second part of channel-width parameter, namely channel layout (e.g. Ceee).
Sonce you resurrected an old thread, it could be that CAPsMAN settings were different in previous versions. In 6.48.3 it seems usage of property secondary-frequency is in line with how it's used under /interface wireless.
Users browsing this forum: avraamd, titinas and 30 guests
