hci
Long time Member
Long time Member
Random Number
Tue Sep 03, 2019 10:57 pm
I would like to generate a simple random number between 1 and 100. If the result is "1" I would like to continue running the script. Anything else and I would like to exit. Anyone know of a way to do that?
The goal is that there is an approximately 1 percent chance the script will run every time it is called.
Jotne
Re: Random Number
Tue Sep 03, 2019 11:26 pm
Google is your friend.
viewtopic.php?f=9&t=56933
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
hci
Long time Member
Long time Member
Re: Random Number
Wed Sep 04, 2019 12:27 am
I was hoping for something simpler such as just using two least significant digits of "total sector writes".
eworm
Re: Random Number
Wed Sep 04, 2019 7:51 am
Sector writes change too seldom.
How about this one?
https://git.eworm.de/cgit/routeros-scri ... tions#n278
Remember that is still a very weak algorithm!
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Re: Random Number
Wed Sep 04, 2019 8:06 am
Removed
MikroTik->Splunk
eworm
Re: Random Number
Wed Sep 04, 2019 8:29 am
Jotne, that's not true and modification is not needed.
:put [ $GetRandom 100 ]
55
Just give the max value.
Jotne
Re: Random Number
Wed Sep 04, 2019 8:37 am
Sorry did not test it that way.
If you use it a a global function I assume its gone after reboot. So you need some script to restore it.
MikroTik->Splunk
eworm
Re: Random Number
Wed Sep 04, 2019 9:44 am
Of course. But it's part of my routeros scripts, so available on every device that has these scripts installed. :D
Alternatively you can make it a local function (replace ":global" with ":local") and put it at the top of your own script.
Users browsing this forum: Baidu [Spider], MSN [Bot] and 9 guests
