mukeshchaubey
Policy to block website in Mikrotik increase CPU
Thu Sep 05, 2019 8:48 am
Hi
Can you let us know what is the best way to block website .we are running ISP and traffic is 2Gbps+1G Peering with a number of customers is approx 2000 (public hotspot )+ home customer 2000 .we are using Mikrotik ccr 1072 and using third party Radius server for AAA .we have approx 100+ list of ip or website name which we want to block .but when we enable it .cpu utilization increase and slow internet browsing experience . I have gone through sum MUM video online at youtube .but that doesn't help us.
Please share me one simple step or example of how to make policy.
Waiting for quick support .thanks
sebastia
Re: Policy to block website in Mikrotik increase CPU
Thu Sep 05, 2019 9:41 pm
what is the /tool profile indicating?
could you share details on how the blocking works?
mukeshchaubey
Fri Sep 06, 2019 7:22 am
find the policy how we are blocking
add action=drop chain=forward dst-address-list=DoT-block
/ip firewall address-list
add address=xmovies8.com list=DoT-block
add address=xmovies8.ru list=DoT-block
add address=xmovies8.tv list=DoT-block
add address=downloadhub.lol list=DoT-block
add address=downloadhub.ws list=DoT-block
add address=downloadhub.ind.in list=DoT-block
add address=downloadhub.wiki list=DoT-block
add address=downloadhub.biz list=DoT-block
add address=downloadhub.net.in list=DoT-block
.........................so on..........
approx 100 such policy
let me know -is it the right way to block the websites or not
DummyPLUG
Fri Sep 06, 2019 8:20 am
I found this method is not reliable when the TTL is just a few second, routeros didn't update the ip fast enough for these domain and will not block them sometime.
mukeshchaubey
Fri Sep 06, 2019 10:47 am
Please suggest me best practices to block. i have list of ip address detail - plz help me how to block .share me one sample. I am new in Miktortik field .
mukeshchaubey
Mon Sep 09, 2019 1:51 pm
Hi
Please support me. How I can block the website so that my Mikrotik ccr 1072 CPU utilization remail normal.waiting for response
R1CH
Forum Veteran
Forum Veteran
Mon Sep 09, 2019 2:16 pm
Redirect DNS to local DNS and then filter at DNS server.
Note that blocking 100% is impossible.
pe1chl
Mon Sep 09, 2019 4:29 pm
DNS over HTTPS that is now being introduced (enabled by default) in webbrowsers will end that possibility...
pe1chl
Mon Sep 09, 2019 4:34 pm
Please show the entire forward chain. Are you using connection tracking? Is the rule placed after the "accept established/related" rule?
Note that such rules are expensive without connection tracking, because they have to be evaluated for each and every packet.
mukeshchaubey
Tue Sep 10, 2019 5:20 am
Hi All
below are the configuartion I have done . let me know if more need to do or how to do ? thanks
------------------100 such sites
mukeshchaubey
Tue Sep 10, 2019 11:51 am
Hi All
share me any link where I can find best way to block websites but it should not increase the CPU and also work fine.
pe1chl
Tue Sep 10, 2019 2:45 pm
I'm afraid there is no such link!
When you "need to block websites" the best advise is to close down your network.
That will create the best overal happiness amongst users and administrators.
mukeshchaubey
Tue Sep 10, 2019 6:02 pm
thanks for wonderful advice
Sob
Tue Sep 10, 2019 6:41 pm
What's the rest of your firewall rules?
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
mukeshchaubey
Thu Sep 12, 2019 1:51 pm
I am sharing sample of my router configuation --plz check and support me for any mistake there ........... currently i have done such configuration which has been enabled now in live network .some websites even get open (i have check that website ip are not getting changed ) .
2nd question :- will it work fine and configuration is correct
add address=abcd.com list=DoT-block
add address=xyz.ru list=DoT-block
add action=drop chain=forward dst-address-list=DoT-block log=yes
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=DoT-block new-routing-mark=block-website passthrough=yes
Sob
Thu Sep 12, 2019 3:17 pm
Your mistake is sharing only few rules, because the rest matters too. But the mangle rule does show the problem, you're checking the list for every single packet. So of course it's going to be slow. You need to check the list only for new connections, mark them and don't check the list again, something like:
/ip firewall mangle
add chain=prerouting connection-state=new dst-address-list=DoT-block action=mark-connection new-connection-mark=block-website passthrough=yes
add chain=prerouting connection-mark=block-website action=mark-routing new-routing-mark=block-website
Or if you're using firewall filter (it doesn't make sense to have both), you need to check the list only once, which is best done when you start your firewall with:
add chain=forward connection-state=established,related,untracked action=accept
add chain=forward connection-state=invalid action=drop
and then you add other rules after these, so only new connections will get to them.
mukeshchaubey
Thu Sep 12, 2019 7:24 pm
/ip firewall mangle
Thanks ..................extremely sorry for my mistake .............I have noted for future post
Users browsing this forum: No registered users and 82 guests
