PsYcH
RBM33G can`t connect winbox neither by IP
Fri Sep 06, 2019 10:04 am
Hello, I have already configured a few mikrotik routers and want to try RBM33G, but cant connect to it. Power supply which I use is 24V 800mA, when i plug it, i see both green and blue led on, after few seconds only blue led stays lit, when trying to find router with winbox by neighbors section, nothing is found, then I set my ip to 192.168.88.22/24 and try to connect with winbox by ip 192.168.88.1 it doesn`t work either. Tried all mikrotik ports, all of them is blinking but just cant connect. Any ideas? No modules connected to ir now.
JohnTRIVOLTA
Re: RBM33G can`t connect winbox neither by IP
Fri Sep 06, 2019 10:23 am
Reset the router and try again !
PsYcH
Fri Sep 06, 2019 11:32 am
Already did this, holding reset button when starting the router, green led starts flashing, that letting reset button.
plisken
Fri Sep 06, 2019 12:26 pm
If you have a firewall on the computer or laptop disable this.
If nothing works try to recover your Mikrotik router with netinstall.
https://www.wirelessinfo.be/mikrotik-netinstall/
Greatings
fmarais007
Fri Sep 06, 2019 12:30 pm
Make sure Winbox is on the latest version (if the device is on the latest RouterOS), or the version Winbox and RouterOS are compatible with.
This might be a basic suggestion, but this caught me a few times.
PsYcH
Mon Sep 09, 2019 3:38 pm
Greatings
That was a good point with firewall, but it didn`t work.
Netinstall can`t find device too, tried on two different computers...
Yeah, winbox was a bit old, but that didn`t help either.
JohnTRIVOLTA
Mon Sep 09, 2019 4:11 pm
Is there plugged any additional peripheral devices - wifi, Lte pci-e card or usb etc...If answer is Yes, remove them and try again .
PsYcH
Mon Sep 09, 2019 6:17 pm
It was, but before I created the forum topic, I have disconnected all other peripherals (it was LTE PCI-E)
JohnTRIVOLTA
Mon Sep 09, 2019 7:02 pm
Hmmm, try to use RS232 serial port !
PsYcH
Thu Sep 12, 2019 11:22 am
Actually going to bring it back to reseller, and try to manage this with him. I`ll update later what was the issue.
Users browsing this forum: No registered users and 78 guests
