Will work with the winbox.exe You have. No special version needed.Awesome, installing it on a spare 3011. Is there a special version of winbox needed? Or any changelog available?
* 7.0beta1 available for testing.I can't read that!
No other instructions was given. Heard hAP ac² and some other devices mentioned, so I guess there's no restrictions on 4G-5G devices only.Have any special instructions been given?
I see a netinstall and an npk, do you need to use netinstall or is it enough to upload the npk and reboot?
Is it limited to certain ARM devices or can it be used on all of them? (I have an unused LHG ac that I could try it on)
Currently running it on a RB3011 so I think it will be all arm devices.Have any special instructions been given?
Drag NPK into Files, double reboot, done. Works well on hAP AC2, no visible difference atleast now. Linux kernel has upgraded from 3.3.5 to 4.14.131.No other instructions was given. Heard hAP ac² and some other devices mentioned, so I guess there's no restrictions on 4G-5G devices only.
Good point!4.14 has longer EOL than 4.19
Why stop at 4.19 ... MT should go for 5.3 ... ROS 7.0 is beta, and linux kernel 5.3 is RC. With current pace, linux kernel will be at least at 5.8 long term before ROS V7 hits stable...So instead of a kernel from 2012 we are now going to have a kernel from 2017.
Lets hope they can update this to the 4.19 version soon.
For real stability you need to have long term support, and also use proven technology.Why stop at 4.19 ... MT should go for 5.3 ... ROS 7.0 is beta, and linux kernel 5.3 is RC. With current pace, linux kernel will be at least at 5.8 long term before ROS V7 hits stable...So instead of a kernel from 2012 we are now going to have a kernel from 2017.
viewtopic.php?f=19&t=93106&start=550#p748615Maybe I am looking with my nose.. but is there a changelog available?
Currently v7 has v6.45.5 feature set. Main change is a new Linux Kernel, rest of features will gradually come out in next builds as for now we want to ensure that v7 is stable on hAP ac^2 and WAPGR LTE/4G/LTE-US boards mainly (and other boards) to get v7 ready for upcomming 5G products.Maybe I am looking with my nose.. but is there a changelog available?
When will you include support for MIPSBE?Currently v7 has v6.45.5 feature set. Main change is a new Linux Kernel, rest of features will gradually come out in next builds as for now we want to ensure that v7 is stable on hAP ac^2 and WAPGR LTE/4G/LTE-US boards mainly (and other boards) to get v7 ready for upcomming 5G products.Maybe I am looking with my nose.. but is there a changelog available?
No current ETA can be given but won't be years...When will you include support for MIPSBE?
Thanks. That makes sense. Looking forward!Currently v7 has v6.45.5 feature set. Main change is a new Linux Kernel, rest of features will gradually come out in next builds as for now we want to ensure that v7 is stable on hAP ac^2 and WAPGR LTE/4G/LTE-US boards mainly (and other boards) to get v7 ready for upcomming 5G products.Maybe I am looking with my nose.. but is there a changelog available?
RouterOS v7 betaafter installing this release on CRS317 lost connectivity via SFP
SFP page shows only module present
after downgrading to 46beta38 SFP shows all info, signal strenght but no link
Added ext4 support ?
[admin@MikroTik] > sys reso print
uptime: 2m16s
version: 7.0beta1 (development)
build-time: Sep/05/2019 15:08:48
[admin@MikroTik] /disk> format-drive file-system=
ext3 fat32
/interface/ovpn-server/server/set protocol=udp
@donewareI imagine people are going to freak about this
Code: Select all/interface/ovpn-server/server/set protocol=udp
is this the real life, or is this "/routing/fantasy"?I lost BGP, but I gained /routing/pimsm and /routing/fantasy,
For now both will work (so importing scripts from v6 that contain whitespaces will execute properly).Some paths are given with "/", some with white space. Is both allowed now?
some traces are visible thoughBGP/MPLS are disabled intentionally, as this is a home router test.
Changelog?
what VPN are you running?Whoa! Just installed 7.0beta1 on a hAP ac^2. Wireless/EoIP/VPN all work.
Routing stack seems to have changed quite dramatically though!
I lost BGP, but I gained /routing/pimsm and /routing/fantasy, although I have no clue what that last one does yet.
I love Mikrotik!
Brave soulCurrently running it on a RB3011 so I think it will be all arm devices.Have any special instructions been given?
i guess not.Code: Select all[admin@MikroTik] > sys reso print uptime: 2m16s version: 7.0beta1 (development) build-time: Sep/05/2019 15:08:48 [admin@MikroTik] /disk> format-drive file-system= ext3 fat32
PPTP- and OpenVPN-clients both work fine. OpenVPN server in UDP mode works as well (just tried it)!what VPN are you running?
Any reason you can think of to actually upgrade & try this v7 ?
Don't think my RB3011 here will become faster or more stable.
One thing is user-land tool to format drive. Another thing is plugging USB stick already formatted with ext4 ... does ROS recognize it?
DO NOT install this on production gear. This release is experimental and should be treated accordingly.So, unless you like to live on the edge (and sometimes slightly over it), then there's no reason to install ROS v7 on your production devices yet.
IKEv2 to ios 12.4?PPTP- and OpenVPN-clients both work fine. OpenVPN server in UDP mode works as well (just tried it)!what VPN are you running?
I love Mikrotik!
Surely, but keeping in mind your multicore CCRs for such a decent money and mostly stable BGP implementation you have there is no wonder a lot of poor it man still hoping for that.We have never promised multicore BGP routing, by the way.
Quite a news, and also nice demo! Will wait for the upcoming v7 stable release (hope you're not Apple so you'll post download link not next year but by maybe November?).
Install labtest Beta before you try the Beta, that helps for meTried twice to install V7 on my hap ac2. Bricked the hell out if it.Thank MikroTik for netinstall...... Wil try beta2
A very careful dance on the table.I imagine people are going to freak about this
The "demo" I saw recently (no idea if it was a hoax) showed at least the use of some more cores for BGP, when multiple peers are present.Surely, but keeping in mind your multicore CCRs for such a decent money and mostly stable BGP implementation you have there is no wonder a lot of poor it man still hoping for that.We have never promised multicore BGP routing, by the way.
Labtest beta? I tried the link on the first page. http://mt.lv/v7
We don't post hoaxes. You can take whatever we post with confidence to the bank.The "demo" I saw recently (no idea if it was a hoax) showed at least the use of some more cores for BGP, when multiple peers are present.Surely, but keeping in mind your multicore CCRs for such a decent money and mostly stable BGP implementation you have there is no wonder a lot of poor it man still hoping for that.We have never promised multicore BGP routing, by the way.
Not a completely multithreaded version which would use most or all cores on a CCR1072, but at least it is something.
(it appeared to handle each peer's updates in a separate process and then send them to a central process to compute the routing table, which was still single-core)
Thinking about it, I wonder if BGP can be made multithreaded by splitting all routes by prefix length. I would think the recomputation of the routing table can be done separately for each prefix length.
(there should be no interlocks needed between updates of routes of different prefix length)
I think what they did in that demo looked like a separate process that handles the updates from a single peer, and it can process the filters.BGP cannot be split in the way you propose. Filters need to be processed in a "run to completion" fashion. Currently the only way to get a semblence of multi threading is to run a thread/process per BGP peer, process the routing update against the filter set, then push the result up to a conductor process that runs the best path selection algorithm against the routes in the active RIB.
Makes sense. Latest firmware on the router board for the latest software.If anyone is having issues installing the beta like I did on a hAP ac2, I had to update the firmware in System>Routerboard before the v7 beta would boot properly.
Works like a charm. Thanks.Try putting your router on latest v6 Stable or Testing release before upgrading to the v7 beta
Wireless works fine on hAP ac^2 (and probably other ipq4000-series devices).Wireless not working?
WorkingWireless not working?
Changelog please
Sent from my SM-A705FN using Tapatalk
What is the current version of the kernel?I believe we used the phrasing, much imroved BGP speed, or something like that
Linux kernel has upgraded from 3.3.5 to 4.14.131.What is the current version of the kernel?I believe we used the phrasing, much imroved BGP speed, or something like that
rb4011 - on table works...Has anyone tested version 7 on RB4011(or RB3011) ?
Cource of this information?Linux kernel has upgraded from 3.3.5 to 4.14.131.
Unpack *.npk and check /lib/modules/ directory.Cource of this information?
Unpacked .npk fileCource of this information?Linux kernel has upgraded from 3.3.5 to 4.14.131.
vermagic=4.14.131 SMP mod_unload ARMv7 p2v8
We just had some spare 3011s so I tried it on one of them, I'll dedicate it to v7 beta installsAny reason you can think of to actually upgrade & try this v7 ?
More stable definitely not, faster likely not ... according to changelog, kindly published by @krisjanisj, not even more functionalities.
Would be much more interested in tile or chr...No current ETA can be given but won't be years...When will you include support for MIPSBE?
which program did you use to unzip?Unpacked .npk fileCource of this information?Linux kernel has upgraded from 3.3.5 to 4.14.131.
[admin@2also] /interface/w60g> set 0 region=
asia australia canada china eu japan no-region-set usa
[admin@2also] > /sys reso print
uptime: 54s
factory-software: 6.41.2
free-memory: 197.4MiB
total-memory: 256.0MiB
cpu: ARMv7
cpu-count: 4
cpu-frequency: 716MHz
cpu-load: 0%
free-hdd-space: 3028.0KiB
total-hdd-space: 15.2MiB
write-sect-since-reboot: 31
write-sect-total: 2960
bad-blocks: 0%
architecture-name: arm
board-name: wAP 60G
platform: MikroTik
judging the previous images to me it seems it was 7z(ip). at least this was the icon i saw on the posted png.which program did you use to unzip?
7zipUnpacked .npk fileCource of this information?Linux kernel has upgraded from 3.3.5 to 4.14.131.
if you check out the video that was posted previously (from april 2019) - the multicore BGP test was run on a CCR1016. ( https://www.youtube.com/watch?v=NbfKplzda7I )I already read CCR support won’t take years and there is no ETA, but... is it expected to be released in this year or not?
Yep.Has anyone tested version 7 on RB4011(or RB3011) ?
I was experiencing the same and also downgraded.Hi,
I've tested 7.0beta1 on a hAP ac² and I was not able to get my configuration with VLANs (used the hw capabilities of the switch chipset) to work. Without VLANs it worked. For the moment I downgraded back to latest stable version.
Best Regards
Tobias
with the growing number of <you-name-it>-over-HTTPS applications around, if your app can be identified in the transmission path, then encryption is not working quite right.L7 application identification
NV3 is coming?
Hopefully its close to this:
Latest linux release 5.2.11 (29 August 2019)
At least based on 5.x and 4.x
Where were the certificates generated?OVPN is not compatible with the previous v6;
v7 ovpn client does not connect to server v6.45 if certificates are used.
Certificates generated by MT CHR, but I won’t say exactly which version, it was a year or two ago. It was definitely version 6.Where were the certificates generated?
In my experience, MT generated certificates don't work with the Windows OVPN desktop client (maybe they do now, I haven't tested recently). Maybe, hopefully, if your certificates are MT generated from v6 or older this is an indication that Mikrotik is now using code from the actual OpenVPN project?
OFDMA is not the same as TDMAWifi6/802.11ax have TDMA as a part of the specification, so there should be no need to implement any proprietary TDMA protocol for it.
It can even do much more than what supposed NV3 would ever do, like splitting bandwidth into multiple streams for different clients at the same time (at OFDM carrier level, similar to what LTE does).
If the Qualcomm Linux driver and firmware passed WIFI6 certification, all these features should be working "out of the box"...
Certificates include a field called key-usage, and various clients and servers treat this field differently, from ignoring its contents completely to only accepting the certificate if a particular usage is listed in that field. So I would not say "MT generated certficiates don't work", I would say "certificates not matching the requirements of the software which uses or receives them" don't work. As no "OpenVPN client" or "OpenVPN server" usage is standardized for certificates, I would expect "tls-client" or "tls-server" to be required, but you have to check.Certificates generated by MT CHR, but I won’t say exactly which version, it was a year or two ago. It was definitely version 6.Where were the certificates generated?
This key usage is set correctly and it worked on version 6.As no "OpenVPN client" or "OpenVPN server" usage is standardized for certificates, I would expect "tls-client" or "tls-server" to be required, but you have to check.
Also, some clients and servers require a minimum key length and minimum key type (RSA/EC) of the certificate to accept it.
What do the logs show for both sides when the client tries to connect?This key usage is set correctly and it worked on version 6.As no "OpenVPN client" or "OpenVPN server" usage is standardized for certificates, I would expect "tls-client" or "tls-server" to be required, but you have to check.
I have
client side certificate: tls client
server side: digital signature, key encipherment, tls server
Does it mean that workaround for SMIPS' 'insufficient space' by installing only necessary individual packages won't work anymore? %)- removed individual packages, only bundle and extra packages will remain
+1We would appreciate further compartmentalizing of Router OS features to increase device efficiency and reduce attack surface.
Put SMB, Torrent, and other things that have no place in ISP infrastructure into another package.
Put BGP, MPLS, and other things that have no place in consumer devices into another package.
Well it actually is like that in v6, but unfortunately those packages are part of the "bundle" and enabled by default, while things more important for consumers like IPv6 are disabled by default.Put BGP, MPLS, and other things that have no place in consumer devices into another package.
Well, I don't have an spare ARM to test the beta7, BUTBut why this whole bundle package thing is even there to begin with, is completely unclear.
Say me please, multicast package included in current beta, or not ?Don't mix up "extra" with "all" packages.
Like I previously said, there will be default bundle + optional extra packages, like user manager, tr069, calea, gps, lcd, ups. I think that's all.
There will be no more system package
Torrent is an essential feature of every router!Wait, torrent wasn't a joke?
@Normis,From Russian MUM 2019. Currently available for downloading from http://mt.lv/v7.
another issue... that I created a workaround
ppoe client (to the ISP) connects but the route that it is adding is not working... I had to create and run the following script to add a proper route that works
/ip/route/set [find where comment="pppoe"] gateway=([:pick [/ip/address/print as-value where interface=pppoe-out1] 0]->"network")
of course I added a comment of "pppoe" to the route that I created in order to get updated with the above script
with the SMB thing i am totally OK. with the torrent - do we know the purpose of the torrent client here?Put SMB, Torrent, and other things that have no place in ISP infrastructure into another package.
i can't stress it any further: IPv6 is a basic stuff now, it shouldn't be a separate package. it is ok if you disable IPv6 forwarding in /ipv6 settings, or we could even have a kill switch for the whole ipv6 protocol stack if one desires (banks, financial institutions and most enterprises are scared ....less), but it must be the part of the basic cocktail, and if you ask me it must be enabled by default.
Now that the kernel is compatible, adding the required userspace glue should be easy for MikroTik.BTW Wireguard works with 4.14.142![]()
Well, it appears that MikroTik is moving from the small-ISP-backbone world to the home consumer world, offering equipment for home usage with features targeted to home users, some of them pre-configured with appropriate default settings for that market.IMO unless a feature/package doesn't have a significant impact on the performance of the device just because it is installed, but has a way to deactivate it in the configuration, it is just fine. why'd anyone bother to uninstall/disable the routing package (BGP or MPLS) if BGP/LDP/MPLS is disabled on its own?
i might rephrase this a bit: extending instead of moving. but that's just my feeling.Well, it appears that MikroTik is moving from the small-ISP-backbone world to the home consumer world
if you ask me, webfig (even with that hideous quickset) ain't for the faint hearted. i deliberately did not mention winbox. people nowadays are "simple". i saw folks getting around on the GUI of OpenWRT but freaking out from webfig on mikrotik. and this also applies to the Tikapp: it is not a consumer tool. i'd say a true home customer friendly solution would be a separate - airport utility like - app for quick setup and no webfig. or a _drastically_ simplified webfig. i doubt that any of the forum visitors should be taken for a role model for the "random home consumer from the 'hood". what seems obvious and simple to us, for the everyday guy is like quantum physics.It would seem natural to have protocols like BGP, OSPF and MPLS disabled by defauit on such devices, to reduce confusion for daddy who wants to make a small change to the config and should not be distraced by a menu called "Routing" which has nothing to do with what he needs but may sound familiar (it is called a Router, what does it do: Routing, probably I need to set something there).
you have my full support on that.To me, it appears that routing and mpls should be disabled by default, ipv6 enabled by default.
no luck with my hap ac2. Tried upgrading from 6.44 and using netinstall. Not a single frame is coming out of this thing on any ethernet port.
Edit: working now. Had to netinstall 6.45.5 only with system + dhcp package, than uploaded 7.0b1 npk and rebooted twice
Both were relevant for my hAP ac2. First had to upgrade the bootloader (I was on 6.44.1) else it would fail to boot (netinstall required).If anyone is having issues installing the beta like I did on a hAP ac2, I had to update the firmware in System>Routerboard before the v7 beta would boot properly.
As a home user, I wish v7 had support for exFAT. Microsoft has made technical specification for exFAT publicly available last month (proof link).Why are people asking for ext4 on mikrotik devices when they should be asking for f2fs?
There are no set release schedules for the next beta releases. We will release beta2 once were done fixing current bugs that were found in beta1 and once we expanded the current feature set (and maybe beta on another platform, who knows!).Out of interest is there an expected release date of new revisions, e.g v7.0beta2 every couple weeks? Or would we only get updates every quarter?
Thanksk
Thanks, I would presume the beta version of V6 would slow down now and more resources allocated to the v7 dev team. No point in flogging a dead horse essentially.There are no set release schedules for the next beta releases. We will release beta2 once were done fixing current bugs that were found in beta1 and once we expanded the current feature set (and maybe beta on another platform, who knows!).
I would hope that by now the infrastructure is in place to work on both versions in parallel without duplicating all the effort... after all, there is still a long period of parallel maintenance ahead before v6 can be buried and forgotten.Thanks, I would presume the beta version of V6 would slow down now and more resources allocated to the v7 dev team. No point in flogging a dead horse essentially.
Thanksk
And CHR also, please!!Even if it's not perfect, we'd love to start testing BGP/MPLS on ARM/Tilera!
CHR +1And CHR also, please!!Even if it's not perfect, we'd love to start testing BGP/MPLS on ARM/Tilera!
Mikrotik can definitely get the SFP information on at least Intel cards, if not all cards that take fibre modules.Any chanfs of the sfp tab on interfaces appear on x86 with this new version? Important information is not reported to sfp card users. What tasks are ready for multiprocessing today in v6? and what happened to be in v7? what is the implementation order for them?
i use mikrotik on a native x86 (non virtualized) core 2 quad, and i have an intel pcie4x dual port sfp card. I don't know exactly which chip is on the board, whether it's 82575EB or 82576, but for me there is no sfp tab when I open the ether1 or ether2 interface. (these are the names of the sfp interfaces on my mikrotik)Mikrotik can definitely get the SFP information on at least Intel cards, if not all cards that take fibre modules.Any chanfs of the sfp tab on interfaces appear on x86 with this new version? Important information is not reported to sfp card users. What tasks are ready for multiprocessing today in v6? and what happened to be in v7? what is the implementation order for them?
Maybe once the v7 beta is out for CHR you could email support@mikrotik.com and request it.
It doesn't matter if IPv6 was/is enabled/disabled in v6, after upgrading to v7 it will be enabled, and upon executing /system reset-configuration , default IPv6 firewall rules will be added.... When you need IPv6, first enable the package, then upgrade your device to latest version...
The default configuration for any package should be installed when it is first enabled, in this case when v7 is first started, but also in v6 when IPv6 is first enabled.It doesn't matter if IPv6 was/is enabled/disabled in v6, after upgrading to v7 it will be enabled, and upon executing /system reset-configuration , default IPv6 firewall rules will be added.
Changes in v7beta2
capsman - improved compatibility between v6 and v7 versions;
tr069-client - address support of server CA certificates;
winbox - re-added OSPF menu;
ppp - fixed "add-default-route" parameter for PPP interfaces;
ppp - fixed OVPN authentication with client certificates;
ppp - improved handling for TLS traffic;
ipsec - enabled EAP client authentication method;
other minor fixes;
https://mt.lv/v7
This time, we are also including the CHR images for more wide testing possibilities. Please report your findings.
And with CHR images!looks like beta2 is out:
viewtopic.php?f=1&t=152003#p752103
Thanks for the information. We can test it now.looks like beta2 is out:
Code: Select allChanges in v7beta2 capsman - improved compatibility between v6 and v7 versions; tr069-client - address support of server CA certificates; winbox - re-added OSPF menu; ppp - fixed "add-default-route" parameter for PPP interfaces; ppp - fixed OVPN authentication with client certificates; ppp - improved handling for TLS traffic; ipsec - enabled EAP client authentication method; other minor fixes; https://mt.lv/v7
What kind of modem do you have ?Updated my hap ac2, and the usb lte interface is not being detected :/
Probably going to have to downgrade.
My main LTE modem is a Huawei K5160, that is a recognised as a "CDC Ethernet Device" in linux (used to work fine in routerOS 6).What kind of modem do you have ?
That isn't possible with stock OpenVPN either! A major omission IMHO.For anyone who's able to test OpenVPN UDP support in RouterOS 7, is it possible to have the OpenVPN server listening on both UDP and TCP at the same time with a single router?
You can run OSPF on a GRE/IPsec tunnel (GRE over IPsec transport), which is a broadly supported construct in other routers and software.Are we going to get VTI support or at least a usable implementation of OpenVPN? I say usable because RouterOS sometimes ignores my explicit interface bindings and bring up dynamic OVPN interfaces. That would be all fine and dandy but I'm running OSPF with redundant WAN links. The horrible site to site support is the biggest shortcoming in RouterOS; you essentially cannot make dynamic routing work reliably with a non RouterOS device on the other end of the tunnel.
Yes, but with stock OpenVPN you can just run multiple copies of the daemon process simultaneously on a single server. In RouterOS, that's not an option.That isn't possible with stock OpenVPN either! A major omission IMHO.For anyone who's able to test OpenVPN UDP support in RouterOS 7, is it possible to have the OpenVPN server listening on both UDP and TCP at the same time with a single router?
Unless you use a lot of trickery that would mean the UDP and the TCP users would be in a different IP pool and subnet. When you want to assign fixed addresses to your clients that is not very practical.Yes, but with stock OpenVPN you can just run multiple copies of the daemon process simultaneously on a single server. In RouterOS, that's not an option.That isn't possible with stock OpenVPN either! A major omission IMHO.For anyone who's able to test OpenVPN UDP support in RouterOS 7, is it possible to have the OpenVPN server listening on both UDP and TCP at the same time with a single router?
