Alijoon
CHR on OpenVZ
Fri Sep 06, 2019 6:37 pm
Hi
I'm going to install CHR on Debian 16.04. The Hypervisor is OpenVZ. The machine has 512MB Ram. When I try to mount the img file, I got the Unknown Error -1 message. I run the following command:
wget http://download2.mikrotik.com/routeros/ ... .5.img.zip -O chr.img.zip && \
gunzip -c chr.img.zip > chr.img && \
mount -o loop,offset=33554944 chr.img /mnt
mount: /mnt: mount failed: Unknown error -1
Any Idea?
torkue
Re: CHR on OpenVZ
Mon Sep 09, 2019 10:47 am
I would suggest to look for a different VPS based on KVM.
Even if we found a solution for mounting the image, the OpenVZ VPS won't be able to run a CHR.
OpenVZ is a container style of virtualization which relies on the host node's kernel, while CHR needs its own kernel.
To run a CHR a full virtualisation solution like hyper-v, qemu/kvm or vmware is requiered.
Alijoon
Re: CHR on OpenVZ
Wed Sep 18, 2019 7:38 am
You right torkue, I should change the provider. Thank you man.
Users browsing this forum: No registered users and 10 guests
