MUM Europe 2020
RedFoxy
Unable to ping/trace from lan
Mon Sep 09, 2019 5:20 pm
Hi!
After I change my router with a Mikrotik RB760iGS I've a trouble, when I try to do a ping from my computer I recieve a 1ms response time like that I'm trying ping the router, same if I do a trace
How can I fix it?
Anumrak
Re: Unable to ping/trace from lan
Mon Sep 09, 2019 5:29 pm
How about to disable your PC firewall for a short period of time and try again?
RedFoxy
Mon Sep 09, 2019 6:25 pm
Already done, no change
BartoszP
Mon Sep 09, 2019 6:45 pm
Show configuration of your router.
I suspect that you have assigned 8.8.8.8 address to interface in your router.
Real admins use real keyboards.
RedFoxy
Mon Sep 09, 2019 7:19 pm
No I don't, I've that trouble with everything:
C:\Users\redfo>ping 1.1.1.1
Esecuzione di Ping 1.1.1.1 con 32 byte di dati:
Risposta da 1.1.1.1: byte=32 durata<1ms TTL=64
Statistiche Ping per 1.1.1.1:
Pacchetti: Trasmessi = 4, Ricevuti = 4,
Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 0ms, Massimo = 0ms, Medio = 0ms
C:\Users\redfo>tracert 1.1.1.1
Traccia instradamento verso one.one.one.one [1.1.1.1]
su un massimo di 30 punti di passaggio:
1 <1 ms <1 ms <1 ms one.one.one.one [1.1.1.1]
C:\Users\redfo>ping master.deltacomsrl.it
Esecuzione di Ping master.deltacomsrl.it [95.211.111.216] con 32 byte di dati:
Risposta da 95.211.111.216: byte=32 durata<1ms TTL=64
Statistiche Ping per 95.211.111.216:
C:\Users\redfo>tracert master.deltacomsrl.it
Traccia instradamento verso master.deltacomsrl.it [95.211.111.216]
1 <1 ms <1 ms <1 ms master.deltacomsrl.it [95.211.111.216]
Traccia completata.
That's my actual config:
# sep/09/2019 18:17:07 by RouterOS 6.45.5
Conf removed
RedFoxy
Mon Sep 09, 2019 7:41 pm
I forgot to tell you that I need top recieve external ping on router to check if it's online by Zabbix, to do that I've a NAT rule:
add action=dst-nat chain=dstnat comment=Ping protocol=icmp to-addresses=\
10.254.254.254
mkx
Mon Sep 09, 2019 8:25 pm
This NAT rule
add action=dst-nat chain=dstnat comment=Ping protocol=icmp to-addresses=10.254.254.254
grabs just any ping request regardless where it starts and what is its destination and redirects it to 10.254.254.254 (which happens to be one of router's addresses). And similar problem is present on many other DST-NAT rules.
You have to make those NAT rules more picky by including some additional filtering options, such as "dst-address=..." or "<in-interface=WAN interface>" ...
BR,
Metod
RedFoxy
Mon Sep 09, 2019 11:20 pm
This NAT rule
thank you! I noticed that just after my last post, thanks for your help!
Users browsing this forum: che, erkexzcx, mkx, MsLrO, nehemiah and 47 guests
