3liswaid
what is the optimum wireless configuration?
Mon Sep 09, 2019 8:46 pm
kindly find my Wireless configuration
 0  R name="MikroTik" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:0B:4C:A9
      arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="MikroTik"
      frequency=2447 band=2ghz-b/g/n channel-width=20/40mhz-XX
      secondary-channel="" scan-list=default wireless-protocol=802.11
      vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
      wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=default compression=no
i can achieve about 65Mbps
while i can achieve 100Mbps when using the wire
my Laptop Wireless intel Dual Band Wireless -AC 8265
and here is an image for the downloading
3liswaid
Re: what is the optimum wireless configuration?
Tue Sep 10, 2019 12:47 am
in addition to the below problem
23:55:14 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
23:55:14 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
23:55:14 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
23:55:14 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
23:55:14 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -61
sep/10 00:04:35 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:04:35 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:04:35 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:04:35 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:04:35 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -69
sep/10 00:12:56 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:12:56 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:12:56 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:12:56 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:12:56 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -64
sep/10 00:12:58 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:12:58 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:12:58 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:12:58 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:12:58 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -65
sep/10 00:13:56 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:13:56 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:13:56 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:13:56 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:13:56 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -56
sep/10 00:13:59 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:13:59 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:13:59 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:13:59 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:13:59 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -60
sep/10 00:14:05 wireless,info B4:C4:FC:5E:78:36@MikroTik: disconnected, received deauth: sending station leaving (3)
3liswaid
Thu Sep 12, 2019 12:07 am
any help please
nichky
Long time Member
Long time Member
Thu Sep 12, 2019 11:46 am
get rid of band=b. Channel-width=20/40mhz-XX depending of the distance
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
3liswaid
Thu Sep 12, 2019 5:39 pm
i did
it's not helping
JohnTRIVOLTA
Thu Sep 12, 2019 6:05 pm
What speeds do you expect to reach ? For me, you need to fix - channel-width=20/40mhz-Ce frequency-mode=superchannel installation=indoor !
After all, it all depends on whether there is radio interference and how strong it is!
UpRunTech
Fri Sep 13, 2019 1:07 am
Have a look at this MUM presentation on improving Wifi speeds. Limiting the available rates can help.
https://mum.mikrotik.com/presentations/ ... 286214.pdf
3liswaid
Fri Sep 13, 2019 12:51 pm
i will try what you suggest
but i expect stable connection with high speed 80 90 mbps
as i'm 2m far away from Wireless router
kristsd
Fri Sep 13, 2019 1:06 pm
You could try reducing tx-power and setting tx-power-mode=all-rates-fixed
to see if that improves the connection ( bear in mind, it will also reduce coverage )
Users browsing this forum: No registered users and 18 guests
