Paternot
Long time Member
Long time Member
GRE dont-fragment - inherit from where?
Tue Sep 10, 2019 5:02 am
Ok, I understand the concept of "don't fragment". But on a GRE interface we have two options:
1) "No". Meaning "ok, fragment if needed"
2) "inherit". Meaning "inherit the value from..." From where? That's what I want to know.
Where does the value come from, if I choose "inherit"?
docmarius
Re: GRE dont-fragment - inherit from where?
Tue Sep 10, 2019 9:58 am
I'm pretty sure it means the parent device' setting if there is one, otherwise yes.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
Paternot
Long time Member
Long time Member
Tue Sep 10, 2019 1:12 pm
Which parent device? The GRE tunnel just exists, it isn't attached to some interface. Would it be the interface through the connection is made?
andriys
Re: GRE dont-fragment - inherit from where?  [SOLVED]
Tue Sep 10, 2019 2:12 pm
I always assumed it inherits it from the packet being encapsulated. Not sure this assumption is correct, though.
16again
Thu Sep 12, 2019 12:46 am
afaik, inherent indeed means "use DF flag" of original packet. Note a GRE interface is unaware of its parent interface, all you specify is an IP local/remote addresses for the tunnel
Paternot
Long time Member
Long time Member
Thu Sep 12, 2019 2:30 am
Well, it makes sense, to use the flag from the encapsulated packet.
docmarius
Sat Sep 14, 2019 12:59 pm
Sorry, that was a bad wording... I meant the interface by which the connection was made through...
pe1chl
Sat Sep 14, 2019 2:09 pm
But I think andriys and others are right, it means to copy don't fragment from the encapsulated packet to the outer GRE packet.
(same for DSCP)
Users browsing this forum: MSN [Bot] and 86 guests
