MUM Europe 2020
sebnx
disable root bridge
Wed Sep 11, 2019 9:29 am
I use Mikrotik routers on our network in order to be able to do bandwidth tests (BTest).
If I connect the Mikrotik on a Netonix, the switch pass the port in "forwarding root" and the Mikrotik becomes Root Bridge ID...
To disable the root bridge I did the following action on the Mikrotik : Bridge > Ports select "Interface > all"
Bridge Port <all> and selected yes on Edge selector.
Is this the right method ??
mkx
Re: disable root bridge
Wed Sep 11, 2019 11:21 am
"root bridge" is a feature of xSTP. If RB in question can not create any loops (e.g. it only has one connection to the rest of network), then you can disable xSTP entirely:
set [ find protocol-mode!=none ] protocol-mode=none
BR,
Metod
sebnx
Wed Sep 11, 2019 9:35 pm
The Mikrotik has only one port plugged into the Netonix switch. Other Mikrotik ports are disabled !
Thanks mkx for the command :)
Users browsing this forum: abjaterza, eworm, himvas, joxa, mrz and 120 guests
