upnort
Sending output of multiple commands to a file
Tue Sep 17, 2019 12:15 am
I want to collect some basic device data and save the information to a file that can be used off device. The information I want to store is something like this:
:local Resource [/system resource print]
:local Routerboard [/system routerboard print]
:local Identity [system identity print]
:local Service [/ip service print]
I want to concatenate the information with something like this:
:local DeviceInfo ($Resource $Routerboard $Identity $Service)
Then paste that information into a file.
do something with "$DeviceInfo" file=DeviceInfo.txt
Thanks again. )
upnort
Re: Sending output of multiple commands to a file
Mon Sep 23, 2019 6:33 pm
I'm still looking for some coaching. :)
Jotne
Tue Sep 24, 2019 7:57 am
In my project Mikrotik for Splunk, I do get this information using syslog to send it out of all routers. See example here: viewtopic.php?f=23&t=137338#p698803
upnort
Thu Sep 26, 2019 6:44 pm
Not what I was looking for, but I see what you did. Thanks. I'm looking to store the information directly into a file rather than a remote log server.
crowfeatherjoe
Fri Oct 07, 2022 9:14 pm
did you ever get this working? im trying to figure something out as well in the same vein now
Jotne
Sat Oct 08, 2022 8:41 am
Remember that high write counts of file may wear out the routers flash.
BrookXVll
Tue Oct 11, 2022 5:24 pm
:local DeviceInfo ($Resource . "\r" . $Routerboard . "\r" . $Identity . "\r" . $Service)
:execute script=":put $DeviceInfo" file=DeviceInfo.txt
rextended
Tue Oct 11, 2022 7:44 pm
Better this...
:execute script="/system resource print; /system routerboard print; /system identity print; /ip service print;" file=DeviceInfo.txt
Users browsing this forum: Google [Bot] and 13 guests
