MUM Europe 2020
Term
Buying new Routerboard - need your recommendations
Wed Sep 18, 2019 10:41 pm
need to buy new routerboard. My question is: can I buy RB4011 or wait for RB with wifi 6 (802.11ax) support? Don't know where will be RBs available with wifi 6.
Thank you.
honzam
Re: Buying new Routerboard - need your recommendations
Wed Sep 18, 2019 11:08 pm
Nobody know.
The new Audience have also only 5 generation - https://mikrotik.com/product/audience
LAN, FTTx, Wireless. ISP operator
Term
Wed Sep 18, 2019 11:19 pm
Hm so rb with wifi6 support will be available maybe in 1 year? 2 years? Need to buy rb in next days/weeks.
flynno
Thu Sep 19, 2019 10:09 am
What are you trying to do that needs wifi?
Term
Thu Sep 19, 2019 10:40 am
Currently have CCR1009 + 2x Unifi AP Pro.
Want to leave that devices and buy new 2x RB with Wifi. Have 1gbps connection at home (pppoe)
erlinden
Thu Sep 19, 2019 11:00 am
Do you want to use the new devices as routers or as accesspoints. In case the latter, just use the cAP ac, hAP ac2 or Audience (wasn't aware of this new device...).
Term
Thu Sep 19, 2019 11:29 am
both. Need LAN and WIFI
erlinden
Thu Sep 19, 2019 3:20 pm
Do you mean by LAN switching (and how many ports?), or is routing also required? Why did you come up with the RB4011 (will do fine in all cases, just not sure wether it is required)?
muetzekoeln
Thu Sep 19, 2019 4:19 pm
gotsprings
Forum Veteran
Forum Veteran
Thu Sep 19, 2019 7:12 pm
Love Tik for routing... but when it comes to wireless... not so much. If you have a connection faster than about 300M, you are going to want to look at other vendors for the wireless.
Also if you are in a very dense WiFi environment... other manufactures handle interference better than Tik.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Term
Mon Oct 14, 2019 12:49 pm
So I still don't know what to buy.
Want RB4011 for wireless. Currently have CCr1009-7G-1C-PC + 2x UniFi Pro. CCR will sell. Maybe will stay with RB4011 as main router and wifi + RB962UiGS for wifi in another room?
heidarren
Mon Oct 14, 2019 12:53 pm
I think your current setup is better in wifi experience
gotsprings
Forum Veteran
Forum Veteran
Mon Oct 14, 2019 9:18 pm
The 4011 has had problems with SFP+ port and with WiFi interfaces. I would hold off on that one.
get 2 cAP ACs and run caps-man on your CCR until mikrotik makes a better WIRELESS ACCESS POINT.
Mark Twain
Term
Tue Oct 15, 2019 7:39 pm
Thank you, didn't know RB4011 has some problems with SFP+ and WiFi.
So will wait some weeks and will see if I will change CCR for something other.
Thank you
johncina7
Sun Oct 20, 2019 8:54 am
I recommend you HP 2530-24G (J9776A). I am already using this device. very good performance.
Users browsing this forum: No registered users and 60 guests
