MUM Europe 2020
chris1906
Can't ping any devices on Lan on the pptp client from the pptp server side
Thu Sep 19, 2019 9:11 pm
Hello everyone.
So I am experiencing an issue with the pptp VPN
For some reason I can't ping any of my devices that is on Lan on the pptp client from the pptp server side.
I can ping all devices on Lan from pptp client to the pptp server. It is almost like my routing is swopped around.
I have made firewall rules to accept VPN connections and have done my routing accordingly to spec.
Can anybody perhaps assist me or maybe point me into the right direction as to what could be causing this? Thanks
chris1906
Re: Can't ping any devices on Lan on the pptp client from the pptp server side
Thu Sep 19, 2019 11:44 pm
here are my configs
add admin-mac=xxxxxxxxxxxxxxxxxxxx auto-mac=no comment=defconf fast-forward=no \
name=bridge
/interface pptp-server
add name=Advcom user=xxxx
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge name=2GHZ ssid=xxxx wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
distance=indoors frequency=auto installation=indoor mode=ap-bridge name=\
5GHZ ssid=Home wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VPN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
/ip ipsec profile
add enc-algorithm=aes-256,aes-128,3des name=profile1
add name=dhcp ranges=192.168.100.10-192.168.100.253
add name=VPN ranges=10.0.0.1,10.0.0.254
add add-arp=yes address-pool=dhcp always-broadcast=yes disabled=no interface=\
bridge lease-time=1d name=defconf
/ppp profile
add local-address=dhcp name=VPN remote-address=VPN
add bridge=bridge comment=defconf interface=2GHZ
add bridge=bridge comment=defconf interface=5GHZ
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=Advcom list=VPN
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=VPN enabled=yes \
max-mru=1400 max-mtu=1400
/interface sstp-server server
set default-profile=default-encryption
add address=192.168.100.254/24 comment=defconf interface=ether2 network=\
192.168.100.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.100.0/24 comment=defconf gateway=192.168.100.254
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.100.254 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=\
udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input protocol=gre
add action=accept chain=input comment="accept vpn" in-interface-list=VPN
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=accept chain=input in-interface-list=WAN
in-interface-list=!LAN
invalid
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment="NVR NAT RULE" disabled=yes dst-port=\
80,6036,554,443 in-interface=ether1 protocol=tcp to-addresses=\
192.168.100.150
add action=masquerade chain=srcnat comment="VPN MASK" out-interface-list=VPN
add action=masquerade chain=srcnat out-interface=Advcom src-address=\
192.168.100.0/24
/ip firewall service-port
set ftp ports=70
add distance=1 gateway=169.1.254.1
add comment="VPN ACCESS ROUTE" distance=1 dst-address=192.168.1.0/24 gateway=\
10.0.0.1
add distance=1 dst-address=192.168.100.0/24 gateway=169.1.254.1
/ip service
set telnet port=90
set ftp port=43
set ssh port=68
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=*4
/ppp secret
add local-address=192.168.100.1 name=admin profile=VPN remote-address=10.0.0.1 \
service=pptp
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=Turnberry
/tool mac-server
/tool mac-server mac-winbox
chris1906
Sat Sep 21, 2019 6:07 pm
Anybody out there that can assist me?
nithinkumar2000
Sat Sep 21, 2019 6:51 pm
here are my configs
name=bridge
/interface wireless
add name=VPN
/ip hotspot profile
/ip ipsec profile
/ppp profile
192.168.100.0
/ip dhcp-client
/ip dns static
udp
invalid
invalid
192.168.100.150
192.168.100.0/24
set ftp ports=70
10.0.0.1
/ip service
set telnet port=90
set ftp port=43
set ssh port=68
/ppp profile
/ppp secret
service=pptp
/system clock
/system identity
set name=Turnberry
/tool mac-server
Please check the IP Mentioned by you in /ppp secret and IP Address of LAN are in different subnets.
Hope this helps!!!
chris1906
Sat Sep 21, 2019 11:47 pm
Hi there
Yes they are. Lan is 192.168.100. 0
And remote is 10.0.0.0
nithinkumar2000
Sun Sep 22, 2019 2:20 pm
Hi there
Please add a static route and try. i hope this may solve the issue...
Users browsing this forum: eworm, faxxe, Google [Bot], mbovenka, prizes, vilpalu and 108 guests
