MUM Europe 2020
jakkwb
Cameras behind 2 mikrotiks and home router
Sat Sep 28, 2019 12:53 am
Hello, I have not messed with customer cameras until now.
Basically, network is laid out like this:
Internet---Mikrotik gateway (nat happens here - everything past is private IPs)---PTP wireless link---2nd Mikrotik (doing DHCP to customers)---Ubiquiti AP---Ubiquiti M5(router mode and NAT)---customers router---Camera (Wanscam)
I need to be able to access customers camera from internet. I have it working plugged into my gateway router using a private IP , I just enter the router IP and the port, and it shows up.
However, accessing the customer camera at his location is not working.
I would love some directions here. Thank you.
Zacharias
Re: Cameras behind 2 mikrotiks and home router
Sat Sep 28, 2019 9:28 am
First, do you have access to your last router ?
pe1chl
Sat Sep 28, 2019 10:45 am
Get a camera that connects outbound to some cloud service, where the customer can connect to that cloud service and view/control their camera.
Allowing inbound access to cameras is so 2010...
Zacharias
Sat Sep 28, 2019 11:48 am
I agree with pe1chl. This is the easiest thing you can do, but since we talk about networking i didn't mention it.
pe1chl
Sat Sep 28, 2019 12:27 pm
It appears that the Wanscam cameras can also do it.
This will work without modification to your network, and is the way to go when you have such a multiple-NAT network.
jakkwb
Sun Sep 29, 2019 2:28 am
Well, I understand everyone's recommendations to cloud serve this, it probably would be an easier solution. However, I really want to know how to make this work like I originally asked for future reference.
pe1chl
Sun Sep 29, 2019 11:24 am
It really isn't practical to have inbound connections in a triple-NAT network like that.
You should at least remove the middle NAT (in the Ubiquiti).
jakkwb
Sun Sep 29, 2019 11:41 pm
Understood. I now have the Ubnt at the remote end bridged instead.
pe1chl
Mon Sep 30, 2019 12:44 am
Then you can setup the usual dstnat to "forward a port" in /ip firewall nat
It may require a /ip firewall filter rule too (not required when you run the default firewall which already handles that).
Of course you need to do that in every NAT router along the path, and it will be difficult to do for more than one user at a time as you can forward each port only to one ultimate destination.
jakkwb
Mon Sep 30, 2019 7:33 am
The only Mikrotik's doing NAT are now my gateway router, and his home router. I am waiting to get his open/forward commands to see if they are correct or not.
jakkwb
Mon Sep 30, 2019 7:37 am
The columns his router shows:
External port, internal port, Internal IP address, protocol, Source IP
example:
15000,15000,10.0.0.10, both, (no source IP entered - is this needed? - if so, which router IP do I put there?
anav
Mon Sep 30, 2019 6:03 pm
Ask in the forum that covers that brand of router??/
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
jakkwb
Tue Oct 01, 2019 4:58 am
was hoping someone could give me further instructions to get this to work. cannot find posts with similar problem with examples on getting it work.
jakkwb
Wed Oct 02, 2019 2:36 am
I actually now have it partly working - I can now access the customers camera locally from both his router and my office. However, we still cannot access it from outside of my network. I can access the test camera attached to my gateway router from outside my network, but not his camera.
What am I missing?
jakkwb
Fri Oct 04, 2019 8:10 am
Anyone care to help me on this?
Users browsing this forum: MSN [Bot] and 91 guests
