freemannnn
Long time Member
Long time Member
user manager nightmare
Sat Sep 28, 2019 7:13 pm
4 years everything was working ok running user manager at a windows pc with virtualbox. no corruptions no problems even with power outages.
i suggested my customer and we bought a rb1100ahx4 level 6 and i install a 16gb sd card.
today (10 days operation) problems started you can see in attachments.
even i reset user manager and started from scratch after 1 hour happened the same. could not access user manager web interface and customers could not logon with the vouchers.
tomorrow i am going to change sd card.
any other suggestion would help. thanx.
Zacharias
Re: user manager nightmare
Sun Sep 29, 2019 2:33 am
Disk I/O error seems like it looses the sd card to me...
Or something is wrong with the sd card it self...
freemannnn
Long time Member
Long time Member
Sun Sep 29, 2019 12:07 pm
I change the sd today i install one 32gb. Lets see how it goes.
Does rb1100 except every sd card?
I mean sdxc is compatible?
Zacharias
Sun Sep 29, 2019 12:38 pm
In the product's specs it just says micro sd, nothing more...so maybe every micro sd card is compatible...i guess you will have to try it...
Users browsing this forum: No registered users and 9 guests
