Bi11
RB4011iGS+ occasionally become inaccessible
Sun Sep 29, 2019 5:56 pm
I've an issue with newly purchased RB4011iGS+. It occasionally become inaccessible.
It happened twice, today and two or three months ago. When it happens,
- Inaccessible via ssh, winbox, www.
- Only responds to ICMP ping.
- RSTP is not working.
- Logging to file is stopped.
- Other services seems working (including Bonding, EoIP tunnel, IP NAT).
I can't reproduce the issue.
- The load is very light. Based on graph, CPU < 2%, Memory < 64M.
- The temperature is below 40C.
- This time the version is 6.44.5, the last time is 6.45.5 or 6.45.6.
- After a reboot, it's back to normal. There is no strange log before the log stops.
I've connected a loop with this RB4011 and two switches (CSS326-24G-2S+ and Unifi US‑8‑150W). When this issue happens, a broadcast storm is generated from RB4011. The storm can be stopped by disconnect the loop manually (unplug the cable, or disable ports on switch) , but RB4011 is still inaccessible. If I directly connect any two ports (under same bridge) on RB4011, it also causes the broadcast storm, which should not be happened in a normal condition, with RSTP protocol enabled.
Autosupout.rif was generated automatically shortly after the log was stopped. Maybe it already knows something.
autosupout.rif.zip
supout.rif was generated after I rebooted the RB4011.
supout.rif.zip
I hope the supout files are helpful.
Zacharias
Forum Veteran
Forum Veteran
Re: RB4011iGS+ occasionally become inaccessible
Sun Sep 29, 2019 6:50 pm
Well am not really sure about that... most probably i think its normal to happen.
But...Why you have such a loop in your network? :shock:
Miracle
Sun Sep 29, 2019 7:09 pm
They are troubles when use Realtek / MediaTek switch.
Try shorter cable ?
Bi11
Tue Oct 08, 2019 12:04 pm
The most important is that RB4011 became inaccessible and only the power reset can bring it back.
I don't know why and I can't reproduce the issue on demand, maybe the loop, maybe not.
Miracle
Thu Oct 10, 2019 4:23 am
Use watchdog it will auto reboot (if it not work try disable interface on otherside).
Zacharias
Forum Veteran
Forum Veteran
Thu Oct 10, 2019 4:05 pm
Watchdog will auto reboot the device only if its unresponsive for a minute...
By default it is enabled.. so since it doesn't auto reboot then the device is not frozen....
Bi11
Tue Oct 15, 2019 5:53 pm
automatic-supout: yes
watchdog-timer: no
The autosupout.rif file was generated, so it did have a software failure.
autosupout.rif is over 400kb but it shows only a few content in supout.rif reader (mikrotik website), most of them is 'died with signal 6'.
Watchdog is disabled in my current settings. I've enabled it now. Hope it can catch the failure.
Thank you all.
dawdler
Wed Oct 23, 2019 3:39 pm
I'm experiencing a very similar issue, twice in 2 weeks now.
No customer traffic, but remote syslogging reports SNMP errors
"2019-10-23 04:15:21.338 x.x.x.x
snmp,warning timeout while waiting for program 79
2019-10-23 04:14:51.307 x.x.x.x
snmp,warning timeout while waiting for program 16
2019-10-23 04:14:21.277 x.x.x.x
snmp,warning timeout while waiting for program 20"
The router is running v6.44.5 , handles 6 LANs with DHCP servers, 30Mbps highest throughput.
low CPU usage <1%. Memory < 10% Temp max 38C.
Reboot resolves issues, have been unable to investigate on site so far so lack of info during failed state, no autosupout.rif
I'm going to configure another RB4011 as my office router - see how that goes.
inteq
Thu Oct 24, 2019 2:15 am
Got any auto-block rules in your firewall? Might get yourself blocked by mistake.
Rules like anti ddos, anti port scan, etc.
Users browsing this forum: No registered users and 73 guests
