XenosTh
Login Problems
Mon Sep 30, 2019 2:11 pm
Hello friends,
I have this problem with an RB2011il. I have deleted admin user, and have created another user with different name with full privileges and different password.
I open winbox, i see my router with it's ip address but when i try to connect with ip and username/pass i get error: Wrong username or password. The only way i can login is by mac address.
The same thing happens when trying to login from web interface.
Does anyone know something about it?
Zacharias
Re: Login Problems
Mon Sep 30, 2019 2:26 pm
When you connect by IP you get wrong password but with Mac no problem? Maybe the error is "could not connect" ?
I' ve never seen anything similar.
If your username and password are correct it will login by MAC and IP.
I Guess you can't login by IP because of wrong configuration...
Whar is your IP and what is the router's IP ?
XenosTh
Re: Login Problems
Mon Sep 30, 2019 3:33 pm
Zacharias thanks for your reply,
All this happens when i am locally connected to router. When you use mac address it connects automatically. When i try to connect with the ip let's say 10.x.x.1 i get the error: Wrong username or password. Even though i am in the same network with router.
The username and password are correct because i myself created them. The configuration is correct and there is nothing like a firewall rule to do this.
The same thing happens when i try to connect remotely to the router.
Zacharias
Re: Login Problems
Mon Sep 30, 2019 3:50 pm
What is your RouterOs version ?
Is your IP in the same subnet as the router's IP ?
Winbox version ?
XenosTh
Re: Login Problems
Mon Sep 30, 2019 4:19 pm
RouterOS version is 6.45.6 mipsbe
Yes as i said i try locally to connect from the same subnet as the router's ip.
Winbox version is 3.18
The same happens in another router rb2011L with 6.43.11 OS version.
Zacharias
Re: Login Problems
Mon Sep 30, 2019 5:01 pm
Update winbox to 3.19 and try again...
XenosTh
Re: Login Problems
Tue Oct 01, 2019 9:40 am
I did that but nothing happened still the same problem!!!
kristsd
Re: Login Problems
Tue Oct 01, 2019 9:53 am
Are you able to connect via Telnet if you re-create admin user with full access?
If you are not able to connect with the newest winbox version, problem could be in the configuration.
XenosTh
Re: Login Problems
Tue Oct 01, 2019 9:58 am
kristsd i will try to hard reset and just re-create user admin with my own password and no configuration at all and see what will happen.
It is very strange behaviour!!!!
kristsd
Re: Login Problems
Tue Oct 01, 2019 10:32 am
Without a configuration you woun't be able to connect through IP telnet.. only MAC telnet.
XenosTh
Re: Login Problems
Tue Oct 01, 2019 10:46 am
I meant without any other configuration - firewall or something else.I have an ip in the same subnet but the problem remains!!!!!!
kristsd
Re: Login Problems
Tue Oct 01, 2019 1:45 pm
When you connect via MAC telnet to the device -
Are you able to ping the IP from the subnet IP you have given to the device you are not able to connect via IP telnet?
XenosTh
Re: Login Problems
Tue Oct 01, 2019 3:33 pm
kristsd yes i can ping just fine.
The only thing i haven't tried yet is to rollback to previous OS version with net install and try again, but i don't have time to do it!!!
I have configured many mikrotik routers but this is the first time that i can't connect using a username and password that i have created!!!!! Remotely or locally from the same network.
XenosTh
Re: Login Problems
Tue Oct 08, 2019 3:05 pm
Guys after hard reset and net install with latest version OS it came around and everything is fine now.
Users browsing this forum: awonglk, simsrw73 and 19 guests
