chris84
Uploadshaping with simple queues does not work
Wed Apr 18, 2007 3:14 pm
hi all,
I'm using a rb500 with mt router-os v3.0beta7.
It is configured as wlan-accesspoint. therefore eth1&wlan1 are configured as bridge.
the upstream is connected to eth1.
my problem is to shape the upload-speed of the clients which are logged in on interface wlan1
I tried http://wiki.mikrotik.com/wiki/PCQ_Examples but nothing is shaped, here's my config.:
 queue type print
8 name="256_up" kind=pcq pcq-rate=256000 pcq-limit=50 pcq-classifier=src-address,dst-address pcq-total-limit=2000
here is a example queue but it doesn't work
queue simple print
 0    name="queue1" target-addresses=192.168.5.10/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=256_up/wireless-default
      limit-at=0/0 max-limit=0/0 total-queue=default-small
do you have any suggestions?
cheers
chris
Diganet
Re: Uploadshaping with simple queues does not work
Wed Apr 18, 2007 3:52 pm
hi all,
 queue type print
queue simple print
cheers
chris
Try downgrade to 2.9.42..
/Henrik
Smith
Thu Apr 19, 2007 11:18 pm
Bridge is not the only way to make it work. Try routing, shaping will work, trust me...
chris84
Fri Apr 20, 2007 8:27 am
Hi Smith,
the problem is that all wlan-accesspoints in our environment are configured as bridge, routing is done by cisco-routers.
does that mean that queues only work in routing-mode?
microlnk
Fri Apr 20, 2007 4:07 pm
no you can do traffic shaping in brige mode
try setting the pcq-classifier to just src-address
Smith
Fri Apr 20, 2007 11:10 pm
Hi Smith,
I am not sure how shaping works in bridge mode, but generaly speaking bridge is bad. Routing gives you wider bandwidth. it doesn't matter if you have cisco router, noone stops you to make routing on every MT, and have cisco as main router.
chris84
Fri Apr 27, 2007 12:22 pm
I got it!
here's the solution:
/interface bridge settings set use-ip-firewall=yes
simple as that :lol:
now the queues are working in bridge mode
Users browsing this forum: DanMos79, jrbarna, plentyofbug, Zoolander06 and 150 guests
