MUM Europe 2020
Smith
simple queue doesn't work when traffic inside same network
Wed Apr 18, 2007 3:27 pm
clients on wlan0
uplink on wlan1
wlan0: 172.16.1.1/24
wlan1: 172.16.2.1/24
users can access internet, routed over wlan1
shaping works for everything that is outside, routed over wlan1
shaping doesn't work when users download between each other. while watching simple queues traffic i can see no traffic, even though i had scp copy from 172.16.1.2 to 172.16.1.3.
Am i the only one with this problem?
simple queue example:
name="user1" target-addresses=172.16.1.3/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8
queue=wireless-default/wireless-default limit-at=256000/256000 max-limit=256000/256000 total-queue=wireless-default
pedja
Long time Member
Long time Member
Thu Apr 19, 2007 9:29 am
Traffic among users in the same IP range does not even reach router so it cannot deal with it.
skynoc
Wed May 16, 2007 8:41 pm
clients for same ip doesnt need the gateway which means it replicate with each other without the need of the router ,
for your situtation you need to assign for each client a subnet of 30 bit
client 1
/ip address add address=192.168.1.1/30 interface=local
client 2
/ip address add address=192.168.2.1/30 interface=local
now both clients needs the router to communicate with each other ,
this situation reduce traffic on the network ,
regards
titius
Re: simple queue doesn't work when traffic inside same network
Fri Aug 17, 2007 4:51 pm
dont quite get your Idea.
whre do I set these addresess.??
This is interesting solution.
Users browsing this forum: No registered users and 111 guests
