volga629
Mikrotik RB951Ui-2HnD Switch VLAN
Thu Oct 03, 2019 4:39 pm
Hello Everyone,
Setup:
OS Ver: 6.45
Model: RB951Ui-2HnD
Bridge Interface BR1_UPLINK
Attached interfaces to bridge: wlan 1 ( vlan 50 tag ) wlan2 ( vlan 20 tag ) ether 2 ( trunk ) ether 3,4,5 ( connected laptop )
Issue: How to mark interfaces 3,4,5 with access vlan 50 so it will pass to ether 2 down stream to ubnt switch trunk port ?
Tried: Switch1 unit set mode secure VLAN always strip on port 3,4,5.
P.S. Wireless links works fine, because tagged with proper vlans on ssid level.
Any help thank you.
sid5632
Re: Mikrotik RB951Ui-2HnD Switch VLAN
Wed Oct 09, 2019 8:21 pm
/interface ethernet switch vlan add ports=switch1-cpu,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=50
/interface ethernet switch port set 1 vlan-mode=secure
/interface ethernet switch port set 2 default-vlan-id=50 vlan-header=always-strip vlan-mode=secure
/interface ethernet switch port set 3 default-vlan-id=50 vlan-header=always-strip vlan-mode=secure
/interface ethernet switch port set 4 default-vlan-id=50 vlan-header=always-strip vlan-mode=secure
/interface ethernet switch port set 5 vlan-mode=secure
Non-obvious stuff:
set 0 is ether 1, set 1 is ether2 etc. set 5 is switch1-cpu
The above assumes you want to manage the unit from VLAN 50 (you need separate config. to create the VLAN interface and put an IP address on it).
If not, sort out a management VLAN first. And make sure you use Safe Mode while doing this, otherwise you might find you cut yourself off.
Users browsing this forum: No registered users and 115 guests
