floaty
adding fib to vrf failed with timeout
Thu Oct 03, 2019 6:56 pm
Version number
7.0beta2
Router's model
model: RouterBOARD 3011UiAS
firmware-type: ipq8060
factory-firmware: 6.42.12
current-firmware: 7.0beta2
upgrade-firmware: 7.0beta2
Steps to reproduce the issue
[admin@RB3011] > ip vrf add name=vrf10
[admin@RB3011] > ip vrf add name=vrf20
[admin@RB3011] > ip vrf add name=vrf30
[admin@RB3011] >
[admin@RB3011] >
[admin@RB3011] > routing table print
Flags: D - dynamic; X - disabled, I - invalid; U - used
[admin@RB3011] >
[admin@RB3011] >
[admin@RB3011] > /routing table add fib name=main-fib vrf=main
[admin@RB3011] > /routing table print
 0     name="main-fib" vrf=main fib
[admin@RB3011] >
[admin@RB3011] > /routing table add fib name=v10-fib vrf=vrf10
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
[admin@RB3011] >
Configuration export (use '/export hide-sensitive' command)
[attached]
Any additional information that would help troubleshoot the issue (screenshots, debug logs, etc.).
[admin@RB3011] > system/sup-output name=v7-vrf-fib
created: 100%
[attached]
We know what happens to people who stay in the middle of the road. They get run over.
floaty
Re: adding fib to vrf failed with timeout
Thu Oct 03, 2019 7:10 pm
Version number
7.0beta2
Router's model
CHR
[admin@CHRv7] > ip vrf add name=vrf10
[admin@CHRv7] > /routing table add fib name=main-fib vrf=main
[admin@CHRv7] >
[admin@CHRv7] > /routing table print
[admin@CHRv7] >
[admin@CHRv7] > /routing table add fib name=v10-fib vrf=vrf10
[admin@CHRv7] >
mrz
Fri Oct 04, 2019 11:51 am
Thank you for the report, at this moment VRFs are not implemented. Adding table to the vrf will simply crash the route.
floaty
Sat Oct 05, 2019 1:05 am
uuh ... yeah ... tried to push an interface into a VRF ... failed ... pushed harder ... saw the error-message ...
... maybe a little "what's-worth-to-test-and-what's-not-implemented-yet-v7-matrix" could be helpfull in the notes ... to avoid 'early redundancy'
... anyway: thumbs-up !
Users browsing this forum: No registered users and 22 guests
