jfreak53
Weave VoIP and mikrotik routerboard, not liking each other
Fri Oct 04, 2019 3:24 am
Trying to configure a mikrotik routerboard to replace a sophos sg105 that was super over complicated for the needs.
Network works great, phones are another issue. We have polycom phones with weave voip services. I have disabled sip alg, and created what I think is basic qos on the phone ips.
I've upped TCP timeout to 36, and udp to 60 min per weaves request.
Weave tells us they don't know anything about mikrotik and we need to change routers.
Basically calls come in fine, we can make calls fine, about 10 to 20 seconds into the call the other end can't hear us speak anymore, it's like a choppy call, in and out. We hear them perfectly fine on our end.
Everything worked good on the sophos. Firewall settings are default.
skylark
Re: Weave VoIP and mikrotik routerboard, not liking each other
Fri Oct 04, 2019 3:59 pm
Does the RouterOS version is updated?
You can try to disable SIP helper or try it enabled with disabled sip-direct-media .
jfreak53
Fri Oct 04, 2019 4:11 pm
RouterOS Version 6.44.4. I've currently got SIP disabled:
jfreak53
Fri Oct 04, 2019 4:18 pm
Below is how I have QOS configured, direct to the IPs of the phones.
jfreak53
Mon Oct 07, 2019 5:31 pm
I my QoS configured correctly? It's still garbled and a major issue. Only happens when 3 phones are off the hook at the same time, meaning it's total bandwidth.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 28 guests
