ilius168
Split UpStream & Downstream
Wed Apr 18, 2007 7:11 pm
Hi, how do i split up stream to gateway1 and downstream to gateway2...
Thx :)
Smith
Wed Apr 18, 2007 10:41 pm
I don't think it is possible without BGP. If you send a packet to some server and start TCP connection that server will send back his packets same way the requesting packets came.
On the other hand. Let's say that i am staring connection with your server and am coming to your gateway 2 (your downstream gateway). You are using gateway 1 to answear to me, different IP. My server tries to find existing connection from your IP and he can't find it. Packet will be droped, connection will not be established.
ilius168
Re: Split UpStream & Downstream
Sun Jul 15, 2007 7:11 am
Dear Smith,
I believe there's way can be done, as some isp' do use DVB which is one way only (downstream) while upstream via FO or other method.
How can we do it with MT?
my current setup is:
SAT
MT-------- Clients
FO
winxp2000
Sun Jul 15, 2007 9:39 pm
It is impossible.
As the fellow said above, the TCP packet need back way from out way.
Equis
Forum Veteran
Forum Veteran
Mon Jul 16, 2007 1:19 am
I do this but you need BGP (or your ISP's help)
Filteres need to be open for both ISP's for your IP Range
ISP 1 Filter open set at your default gateway (send)
ISP 2 Filter open and advertise your IP's (receive)
With this setup I have turned 4m/4m shdsl and a 8Meg/300k ADSL into a single 8meg/4Meg connection :-)
ilius168
Mon Jul 16, 2007 1:54 am
What if the ISP is not friendly with BGP ? :-(
Equis
Forum Veteran
Forum Veteran
Mon Jul 16, 2007 2:01 am
Your Screwed... :-(
JR
Tue Jul 17, 2007 6:45 pm
Your SAT provider should be able to help.
Create a tunnel (via FO) to SAT provider, this will be for upstream, OR get an IP from SAT provider and use it as your source (out interface) IP (so the only route back will be via SAT DVB).
Downstream via DVB IP (set by SAT provider)
ilius168
Wed Jul 18, 2007 2:57 am
Your Screwed... :-(
That i know... thanks!
Good answer though, mate!! :P
JR
Mon Jul 23, 2007 9:12 pm
If you place a bag under de mango tree, will mangoes fall into it?
sten
Forum Veteran
Forum Veteran
Mon Jul 23, 2007 11:47 pm
if the FO would allow your customer subnet through their source-filters (or if they are too ignorant to have any), you should be able to do this without any active routing protocols. Then you would just need to do default route one way and let the returning traffic come the other way.
If you NAT your customers then this could prove more tricky but not impossible. The key is the FO's source filters.
ilius168
Mon Aug 20, 2007 6:10 pm
got any idea how to do this in MT? anyone?
changeip
Mon Aug 20, 2007 7:08 pm
yes, set your default gateway to the FO port. Make sure all outbound connections, DNS entries, etc, specify your SAT connections IP address. Basically advertise the IP you want them to come in on, and send them out whichever way you want with the default gateway. You will probably end up using src-nat to stick the SAT ip on the outbound traffic if required. Just hope your sat provider doesn't do BCP38; which they should be really - if your not on your network then your helping spoof ips in ddos attacks
sten
Forum Veteran
Forum Veteran
Mon Aug 20, 2007 8:29 pm
Let's hope they have, and if they have, then simply ask them to add your subnet(s) to their ingress filters.
Always filter the source address of your customers (it will help you sleep at night).
t3rm
Sun Aug 26, 2007 9:13 pm
It is POSSIBLE to do it without you having interfere with the BGP option since the BGP is in ISP side.
Once you get ip addresses from your ISP, of course packets from everywhere around the world would come to your side from your ISP.
But for the packets leaving your side, can be choose which gateway to forward it through. Either with the gateway IP of the ISP or the other gateway of other ISP.
As long as the other upstream ISP open their upstream filter and let your IP address from your ISP , pass through.
- Rio.Martin -
Users browsing this forum: LuizMeier, thefear, uk123 and 201 guests
