MUM Europe 2020
raoulalien
Forwarding port 443 causes internet problems to anyone else?
Sat Oct 05, 2019 3:23 pm
In the last couple of weeks, whenever I forward port tcp 443 I get internet issues.
All my other port forwardings work fine, except this one.
And it's disabled in IP SERVICES before someone asks :)
Seems to be on the latest versions, because today I messed around with an 6.43.16 RB and it worked fine.
Am I crazy? Or is this happening to someone else?
Zacharias
Re: Forwarding port 443 causes internet problems to anyone else?
Tue Oct 08, 2019 2:02 am
Https uses port 443... so by forwarding this port you create problems...!
Sob
Tue Oct 08, 2019 3:22 am
Let me fix it:
Https uses port 443... so by incorrectly forwarding this port you can create problems...!
And whether it's the case, probably yes, but it's hard to tell exactly if you don't show your config.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
k6ccc
Tue Oct 08, 2019 7:36 am
My first guess is that your forwarding rule is not specific enough. For example, if you forward all port 443 traffic to something, then ALL traffic including your outbound https traffic will go there. On the other hand, it you only forward port 443 traffic that is inbound on your WAN connection, then your outbound http traffic will be unaffected.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
IPANetEngineer
Trainer
Trainer
Tue Oct 08, 2019 8:50 pm
What is the source you are trying to forward from and the destination?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Users browsing this forum: CZFan, durrsaku, rhczaksa and 62 guests
