Barcode
Sharing the bandwidth doesn't work
Sun Oct 06, 2019 6:52 pm
Hello!
I just bought a MikroTik RB941-2nD-TC router, to share the bandwidth with my computer and with my brother's computer and I did all the things like in the tutorials and it doesn't work...
My main router is a Telekom router, model is Speedport Entry 2i maybe this router has something to do with it?
Zacharias
Forum Veteran
Forum Veteran
Re: Sharing the bandwidth doesn't work
Tue Oct 08, 2019 1:36 am
But you don't say what exactly you did....
How did you try to share that bandwidth? Provide more details...
Barcode
Tue Oct 08, 2019 1:13 pm
Well, in queue list I tried to add both computers with IP and the same amount of limit, then I tried it with ether2 and ether 4 still nothing, tried doing with a parent queue, still nothing, tried adding pcq-s for upload and download and nothing.
Zacharias
Forum Veteran
Forum Veteran
Tue Oct 08, 2019 3:41 pm
You can export your queue configuration and post it here...
Barcode
Tue Oct 08, 2019 4:13 pm
0 name="queue1" target=ether2 parent=queue3 packet-marks="" priority=8/8
queue=default-small/default-small limit-at=0/0 max-limit=11M/25M
burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s bucket-size=0.1/0.1
1 name="queue2" target=ether4 parent=queue3 packet-marks="" priority=8/8
2 name="queue3" target=ether1 parent=none packet-marks="" priority=8/8
queue=default-small/default-small limit-at=0/0 max-limit=0/0
Zacharias
Forum Veteran
Forum Veteran
Tue Oct 08, 2019 8:58 pm
In your parent set Max download and upload limit, which is the total available bandwidth...
Then in the advaced tab of your parent select pcq algorithm.
Barcode
Tue Oct 08, 2019 9:23 pm
Still doesn't work
Zacharias
Forum Veteran
Forum Veteran
Tue Oct 08, 2019 10:40 pm
Put your parent on top and all the childs bellow the parent..
Barcode
Tue Oct 08, 2019 10:52 pm
Yeah, I did it like this
Zacharias
Forum Veteran
Forum Veteran
Tue Oct 08, 2019 11:15 pm
Did it work? How are you testing if it works or not?
Barcode
Tue Oct 08, 2019 11:18 pm
I tested it on speedtest, and I'm still getting the full bandwidth
Zacharias
Forum Veteran
Forum Veteran
Tue Oct 08, 2019 11:45 pm
Every time i look at your export i find mistakes.. :D
On your parent interface you ve set as target ether1, this is wrong...
Parents target should be both interfaces, ether2 and ether4 in your case.. either add them both or add them in a bridge and add that bridge as a target...
Barcode
Tue Oct 08, 2019 11:52 pm
I set the target eth2,4 still not working :(
2 name="queue3" target=ether2,ether4 parent=none packet-marks="" priority=8/8
queue=pcq-upload-default/pcq-upload-default limit-at=0/0
max-limit=50M/22M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
bucket-size=0.1/0.1
Zacharias
Forum Veteran
Forum Veteran
Tue Oct 08, 2019 11:58 pm
Your childs are still not bellow your parent... parent must be in position 0, child1 in position 2, child2 in position 3....
Also on the parents advanced tab use pcq upload for the upload and pcq download for the download..Not pcq upload to both...
Barcode
Wed Oct 09, 2019 12:11 am
Still dont
0 name="queue3" target=ether2,ether4 parent=none packet-marks="" priority=8/8
queue=pcq-upload-default/pcq-download-default limit-at=0/0
max-limit=22M/50M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
bucket-size=0.1/0.1
1 name="queue1" target=ether2 parent=queue3 packet-marks="" priority=8/8
max-limit=11M/25M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
bucket-size=0.1/0.1
2 name="queue2" target=ether4 parent=queue3 packet-marks="" priority=8/8
bucket-size=0.1/0.1
Zacharias
Forum Veteran
Forum Veteran
Wed Oct 09, 2019 12:16 am
Please post your code inside code tags..
Childs do not need to have pcq selected... parent does.. anyways..
In your firewall is fasttrack enabled? If yes delete it..
Barcode
Wed Oct 09, 2019 12:28 am
I fixed the pcqs, and disabled fasttrack then rebooted the router still doesn't work..
Zacharias
Forum Veteran
Forum Veteran
Wed Oct 09, 2019 8:26 pm
Simple queues are really simple to create... am sure you miss something...
I will have to see your whole router configuration because certainly you do something wrong..
In the wiki you can find examples of simple queues..
Barcode
Wed Oct 09, 2019 10:17 pm
Yeah, that's what I'm saying, it's really simple, and I can google aswell :D.
That's why I'm questioning the thing that maybe my telekom router fucks this all up.
If u tell me how I can send you all the router's configuration i'll send it.
Zacharias
Forum Veteran
Forum Veteran
Wed Oct 09, 2019 10:20 pm
You can export your configuration with hide-sensitive and post it here inside code tags...
Barcode
Wed Oct 09, 2019 10:29 pm
Here it is
[admin@MikroTik] > /export hide-sensitive
# oct/09/2019 21:25:09 by RouterOS 6.45.3
# software id = 427L-2LVJ
# model = RB941-2nD
# serial number = 93710A7F5981
add admin-mac=74:4D:28:C2:3F:CA auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=20/40mhz-Ce country=hungary disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain mode=ap-bridge ssid=MikroTik-C23FCE wireless-protocol=802.11
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge lease-time=3d name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/queue simple
add max-limit=22M/50M name=queue3 packet-marks="" queue=pcq-upload-default/pcq-download-default target=ether2,ether4
add max-limit=11M/25M name=queue1 parent=queue3 queue=default/default target=ether2
add max-limit=11M/25M name=queue2 parent=queue3 queue=default/default target=ether4
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.254 client-id=1:b0:6e:bf:c5:56:a8 mac-address=B0:6E:BF:C5:56:A8 server=defconf
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input connection-type="" dst-port=8291 protocol=tcp
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=accept chain=input comment=remote dst-port=8291 protocol=tcp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=192.168.89.0/24
/ppp secret
add name=vpn
/system clock
set time-zone-name=Europe/Budapest
/tool mac-server
/tool mac-server mac-winbox
Zacharias
Forum Veteran
Forum Veteran
Thu Oct 10, 2019 12:06 am
Please put your code inside code tags...
I do not see anything wrong! It should work...
Try to put in your parent all your subnet as target, instead of ether3,4 , put 192.168.88.0/24 and in your childs instead of ether 3 and ether 4 as targets use the IP addresses of your computers...
Barcode
Thu Oct 10, 2019 12:16 am
Idk what are code tags, but still doesn't work with the IPs
CZFan
Thu Oct 10, 2019 1:47 am
You need to elaborate on what you mean "share" with your brother. If you want to share the bandwidth dynamically, i.e. when you not using, he gets 100% and vice versa, then all you need is the below:
If you both use internet, then it will dynamically share, to test, start a speed test on both pc's at the same time
PS. Note the "code tags"
/queue simple
add max-limit=22M/50M name=Q1 queue=pcq-upload-default/pcq-download-default target=192.168.88.0/24
MTCNA, MTCTCE, MTCRE & MTCINE
Zacharias
Forum Veteran
Forum Veteran
Thu Oct 10, 2019 4:00 pm
Czfan if you see the earlier posts he uses simple queues with parents and childs... if you limit the childs up/down then even if there is more bandwidth available he will not get it...
Also if he does use all the subnet 192.168.88.0/24 as you told him then he will limit everyones traffic in the network and Not only to the computers he actually wants to.
The implementation he exported earlier seems just fine, i think there is a mistake somewhere else but i will have to see all the routers configuration...
xvo
Long time Member
Long time Member
Thu Oct 10, 2019 4:25 pm
That should work:
/queue simple
add dst=ether1 max-limit=22M/50M name=queue3 queue=default/default target=ether2,ether4
add dst=ether1 limit-at=11M/25M max-limit=22M/50M name=queue1 parent=queue3 queue=default/default target=ether2
add dst=ether1 limit-at=11M/25M max-limit=22M/50M name=queue2 parent=queue3 queue=default/default target=ether4
However, I'm not sure about slave interfaces as a target. Perhaps that has to be changed to ip address ranges.
Also please be sure that max-limit is at least 5-10% lower than achievable provider speed.
P.s.: also you need to move this address to the bridge:
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
instead of:
Barcode
Wed Oct 16, 2019 9:18 am
/queue simple
This one works, but I want to limit both of our bandwidth equally, maybe you can help with that aswell?
Barcode
Wed Oct 16, 2019 9:19 am
That should work:
/queue simple
instead of:
Did this, and still nothing.
xvo
Long time Member
Long time Member
Wed Oct 16, 2019 10:19 am
Did you also try to change targets from interface names to address ranges?
Barcode
Wed Oct 16, 2019 12:15 pm
Yep, did that before
xvo
Long time Member
Long time Member
Wed Oct 16, 2019 12:58 pm
I have no other ideas.
Almost identical config works for me.
Barcode
Wed Oct 16, 2019 1:29 pm
Yeah, that's why I wrote this topic, and my guess is that my main telekom router is blocking something or idk
xvo
Long time Member
Long time Member
Wed Oct 16, 2019 4:49 pm
Try setting max-limit much lower than your actual speed (5M/10M for example) and see if the queues still don't work.
To rule out the possibility, that your ISP shaper takes effect before your mikrotik.
Barcode
Wed Oct 16, 2019 7:43 pm
Tried that also, also not working
xvo
Long time Member
Long time Member
Wed Oct 16, 2019 8:03 pm
Still can't find anything in your config that could interfere with queues.
ChristopherFS
Wed Oct 16, 2019 8:34 pm
Good Afternoon,
Try disable fasttrack connection!!!
If you use the router out-of box probally it came with fasttrack enabled.
Barcode
Thu Oct 17, 2019 2:06 pm
It's disabled.
Zacharias
Forum Veteran
Forum Veteran
Thu Oct 17, 2019 2:37 pm
Your queues are correct..
so either you test it the wrong way or traffic shapping happens before the MikroTik...
Users browsing this forum: Google [Bot] and 24 guests
