MUM Europe 2020
harjeetv
Hotspot allow addresslist and drop rest
Mon Oct 07, 2019 2:29 pm
I have been trying to allow only certain ip pool for hotspot authentication and drop all other for single ethernet port.
configuration is as follows:
/ip firewall address-list
add address=172.16.118.64/26 comment="Ether 5 Allowed Client IP's" list="ether5 allowed ip"
/ip firewall filter (this rule is in position 0)
add action=drop chain=input in-interface=ether5 log=yes log-prefix="Dropped " src-address-list="!ether5 allowed ip"
still i can see other IP address being authenticated from ether5 for hotspot. i had tried changing the chain to forward, hs-input but still does not work.
dmitris
Re: Hotspot allow addresslist and drop rest
Mon Oct 07, 2019 2:45 pm
Try in mangle on prerouting chain...
/ip firewall mangle
add action=drop chain=prerouting in-interface=ether5 log=yes log-prefix="Dropped " src-address-list="!ether5 allowed ip"
harjeetv
Mon Oct 07, 2019 2:51 pm
/ip firewall mangle
But Firewall Mangle does not have action=drop
dmitris
Mon Oct 07, 2019 4:59 pm
Sorry my fault..
Look at mikrotik packet flow diagramm:
https://wiki.mikrotik.com/wiki/Manual:Packet_Flow
"hotspot-in" on prerouting chain and it's first stage where packet goes this is why u can't block others ip. I think you should setup ip blocking in hotspot itself....
harjeetv
Tue Oct 08, 2019 5:56 am
There must be a way. I don't want the Client IP's to pass through router and then reject with radius server. Instead i want to reject in the router interface itself.
laxmimikrotik
Re: Hotspot allow addresslist and drop rest  [SOLVED]
Tue Oct 08, 2019 6:16 am
HI,
You can do it in IP>>Hotspot>IP-Binding.
In this section you can achieve your requirement.
let me know.!!
http://laxmidharnetworking.blogspot.com ... tspot.html
Thanks.
Every problem Has Solution .
ip-noc Team.
MTCNA ,MTCRE,
harjeetv
Tue Oct 08, 2019 8:01 am
Great, didn't knew there was a regular(not bypass) option too, will test using this. Thanks
HI,
let me know.!!
Users browsing this forum: bpwl, Google [Bot], pe1chl and 122 guests
