oooscar
Login API pear2/Net_RouterOS 6.45.x
Mon Oct 07, 2019 8:32 pm
I did read about new login API from 6.45.x version. https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
Now I have several routers where I connect throw pear2/Net_RouterOS with versions older that 6.45 (arround 1000 routers). And now there start to come some with new RouterOS version.
I did found a new version on pear2/Net_RouterOS 1.0.0b6 (i'm using 1.0.0.b5) but on the change log I didn't found login differences.
So how I have to do to keep working the api call with both verions ?
I'm doing at the moment:
$this->util = new RouterOS\Util($this->client = new RouterOS\Client($ip,$userRouter,$passRouter,null,null,$tiempoEspera));
Thanks,
oooscar
Re: Login API pear2/Net_RouterOS 6.45.x
Tue Oct 08, 2019 9:05 pm
No one ? There is no fix ?
mrz
Wed Oct 09, 2019 12:22 pm
I do not see a problem you just try new login method and fall back if you receive ret, as shown in the python example:
https://wiki.mikrotik.com/wiki/Manual:A ... ple_client
See "login" function
oooscar
Wed Oct 09, 2019 2:48 pm
Thanks mrz,
but I'm using pers2/Net_RouterOS PHP class, I wonder if there is any update to don't change the code directly.
it should be here:
private static function _login(
Communicator $com,
$username,
$password = '',
$timeout = null
$request = new Request('/login');
$request->send($com);
$response = new Response($com, false, $timeout);
$request->setArgument('name', $username);
'response',
'00' . md5(
chr(0) . $password
. pack('H*', $response->getProperty('ret'))
return $response->getType() === Response::TYPE_FINAL
&& null === $response->getProperty('ret');
If no ones have donne i will try but just if someone has done it would be grate to be shared.
Thanks,
oooscar
Fri Oct 11, 2019 5:39 pm
the code in this link is working for me until new realse or the API comes over.
https://github.com/pear2/Net_RouterOS/issues/37
Thanks,
Users browsing this forum: No registered users and 14 guests
