Mik3
NordVPN disconnected at 1 hour
Tue Oct 08, 2019 1:57 am
I tried what nordvpn suggests on creating ipsec VPN connection on mikrotik at https://support.nordvpn.com/Connectivit ... ordVPN.htm
Unfortunately, it gets disconnected after 1 hour with killing ike2 SA message in the log.
I changed dpd and lifetime settings to no avail.
Can anybody help please.
TIA
msatter
Re: NordVPN disconnected at 1 hour
Tue Oct 08, 2019 1:12 pm
Do you have a subscription with NordVPN and which version of RouterOS are you using?
On the linked page you see a link to the original page by Mikrotik and that one is completer.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Mik3
Tue Oct 08, 2019 8:01 pm
Yes, subsribed.
4.56.6 with the same firmware version.
I read them both. Unfortunately I can't figure out where the problem resides.
Mik3
Fri Oct 18, 2019 1:59 am
*bump
msatter
Fri Oct 18, 2019 12:33 pm
I have no idea what this could cause and could mail support@mikrotik.com about this.
Info about support: https://mikrotik.com/support
Running:
Mik3
Wed Oct 23, 2019 12:24 am
I don't know how to reconnect to VPN. There's no option or command to restart it. Disable/enabling of profile or policy won't do either. The only way I've found so far is to reboot the router so as to connect to VPN for just another 60 minutes..
Mik3
Tue Nov 12, 2019 2:19 am
RB951g replaced by RB4011 and now everything is ok. So it seems that RB951 is too weak to be used for ipsec ikev2 scenarios.
msatter
Tue Nov 12, 2019 2:25 pm
Good to read that this resolved. The 4011 is a powerfull device and the problems 5GHz WAN should now be resolved also.
Running:
Users browsing this forum: No registered users and 20 guests
