Edified
MacOS Catalina, iOS, Catalyst, SwiftUI & Wine
Tue Oct 08, 2019 6:18 am
I almost accidentally upgraded to MacOS Catalina, which would have hosed my Wineskin'd Winbox.
Now that there's an iOS app it seems that a native MacOS app shouldn't be far behind. If nothing else at least a Catalyst iOS port would be enough to do the basics, even if it doesn't have all the features of Winbox at first.
I know that Crossover is working on a hack and Mikrotik may well release a 64bit Winbox but at this point, with the iOS app now a permanent fixture and SwiftUI just arrivingI would love to see a native MacOS "Winbox". Might be time for a new name too, I've always called my Wine ports simply "MikroTik" which would be an easy first choice.
normis
Re: MacOS Catalina, iOS, Catalyst, SwiftUI & Wine
Tue Oct 08, 2019 8:28 am
We are aware and are working on all of that.
Nevon
Thu Oct 10, 2019 8:58 pm
Waiting.... ^^
DotTest37
Thu Oct 10, 2019 9:11 pm
Waiting.... ^^
Me too
MtHoodlum
Fri Oct 11, 2019 6:06 am
I did upgrade to Catalina. Not waiting.
IsiaNT
Fri Oct 11, 2019 2:57 pm
up
needed
normis
Fri Oct 11, 2019 3:13 pm
drzen
Fri Oct 11, 2019 3:34 pm
I want it.
v.
(Rate my posts? If you want... no pressure...)
zentavr
Fri Oct 11, 2019 4:20 pm
I wonder if there is any 64-bit executable of WinBox available? 32-bit executable cannot be executed with wine at Catalina :(
normis
Fri Oct 11, 2019 4:22 pm
zentavr have you read this topic, before commenting?
pe1chl
Fri Oct 11, 2019 4:27 pm
That part should be trivial to get working. Now show a screenshot where you are actually logged in to a router :-)
victorsoares
Fri Oct 11, 2019 4:30 pm
=O I want it sooo bad. MacOS beta Developer here, I would be happy to send feedback on it.
MTCNA MTCRE
TimurA
Fri Oct 11, 2019 5:59 pm
want now! give me this version :)
xrtc
Fri Oct 11, 2019 8:50 pm
yes please a public RC version would be nice !
florid
Sat Oct 12, 2019 5:19 am
consider to name it Macbox instead of winbox 3.20?
Kombat1978
Sat Oct 12, 2019 9:41 am
Hi guys,
I did not accidentally upgrade to Catalina I did it on purpose. So just checking if there is any update for configuring my router from my Mac.
The fact that there is an app for iPhone means it cannot be far behind. Hoping.
Have goodie
pe1chl
Sat Oct 12, 2019 11:47 am
Why?? It still is a Windows program, isn't it? 64-bit executables are not something specific to the Mac, Windows and Linux have them as well.
(but those platforms also support 32-bit executables on the same system, something the newer MacOS Catalina cannot do)
coenkcore
Sat Oct 12, 2019 4:26 pm
waiting for release with macOS catalina support :D
DotTest37
Sun Oct 13, 2019 3:02 am
On October 09 Normis wrote on another forum "Several other topics exist about this already. We are working on winbox64"
Normis,, you are interpreting the forums the wrong way.
No, no, no, we dont want no "Windows-based stuff",,
We need native MAC !! MAC please.
Nobody can say we havent been patient all these years !
hummer1028
Sun Oct 13, 2019 3:35 pm
me too...
w0lt
Sun Oct 13, 2019 5:21 pm
Normis, quit teasing us !! :lol: 8) :lol:
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
punkaker
Mon Oct 14, 2019 1:48 pm
Same situation here with all our Laptops. Will use VMs in the meanwhile, but hoping there will be a new release for MAC Catalina soon.
Thanks for the effort.
normis
Mon Oct 14, 2019 2:01 pm
While you are waiting for the new 64bit exe file to be released soon, you can already prepare your macOS catalina systems according to these instructions:
If you have used Wine previously, we recommend you first delete the previous Wine application and the Wine settings directory in your home folder:
rm -rf /Applications/Wine*
rm -rf ~/.wine/
To run Winbox64 the following steps are required.
Install Wine Staging from WineHQ official download page https://dl.winehq.org/wine-builds/macosx/download.html
and make sure you have downloaded the winbox64.exe executable from the MikroTik download page.
During installation, you must mark "64 bit support" (by default it is not checked).
In macOS terminal, make sure your set to use ZSH as the new shell like this (and restart Terminal after this command):
chsh -s /bin/zsh
Edit your zprofile file to add environment variables, pointing the wine64 command to the correct installation path of Wine Staging:
nano ~/.zprofile
The file should look like this (make sure your paths are correct here):
export PATH="/Applications/Wine Staging.app/Contents/Resources/wine/bin:$PATH"
export FREETYPE_PROPERTIES="truetype:interpreter-version=35"
export DYLD_FALLBACK_LIBRARY_PATH="/usr/lib:/opt/X11/lib:$DYLD_FALLBACK_LIBRARY_PATH"
Restart (quit and reopen) your macOS terminal
Launch Winbox64 with wine64 like this:
wine64 "/Applications/winbox64.exe"
matgreg91
Mon Oct 14, 2019 2:13 pm
Hello everyone,
what about The Dude? Do you plan to release a 64 bit version of this software too?
Thank you
normis
Mon Oct 14, 2019 2:21 pm
Dude currently no immediate plans. Run it in Windows.
victorsoares
Mon Oct 14, 2019 5:36 pm
rm -rf ~/.wine/
chsh -s /bin/zsh
nano ~/.zprofile
All done here, just waiting for it now =)
MTCNA MTCRE
anatod
Mon Oct 14, 2019 5:58 pm
rm -rf ~/.wine/
chsh -s /bin/zsh
nano ~/.zprofile
where is the winbox64 link?
Custom Software Suite for ISP
victorsoares
Mon Oct 14, 2019 6:59 pm
rm -rf ~/.wine/
chsh -s /bin/zsh
nano ~/.zprofile
We'll have to wait for it.
MTCNA MTCRE
eddieb
Mon Oct 14, 2019 8:28 pm
Wow, that is bad, so I have to buy 1 windows machine to run dude ????
BAD BAD BAD
Running 6.45.7 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
pe1chl
Mon Oct 14, 2019 8:45 pm
BAD BAD BAD
I suppose you understand that the main people to blame here are Apple, who took away your ability to run 32-bit code?
Other platforms support 32-bit code on 64-bit CPU/OS, and Apple did the same until they took this away from you.
Winbox/Dude is likely not the only software that no longer works for you due to this change.
normis
Tue Oct 15, 2019 8:59 am
Dude is a Windows program and has always been.
eddieb
Tue Oct 15, 2019 9:03 am
nothing wrong with a windows program, but please make it 64bit ...
I don't need OSX stuff, but 64bit would be nice
pe1chl
Tue Oct 15, 2019 11:17 am
But since some time there is also some Dude functionality (not everything) in Webfig!
I still think that is the way to the future... as nice a a native application may be, everyone is moving to web applications,
and the possibilities there have improved.
loockas
Tue Oct 15, 2019 1:53 pm
It's works :) But i have problem with import/export addresses.cdb, explorer was not shown. Logs:
0009:err:virtual:map_file_into_view failed to set PROT_EXEC on file map, noexec filesystem?
0009:err:virtual:virtual_map_section mapping 0xed0000 1000 000000000 failed
alternatively i can copy the file to ~/.wine/drive_c/users/myuser/Application\ Data/Mikrotik/Winbox/, but i have don't idea how doing export ("save as" also not working)...
victorsoares
Tue Oct 15, 2019 3:42 pm
I know it's probably something dumb, but how do I create a shortcut for this on Catalina? I always used PlayonMac to do this things, but for now the app doesn't work on 10.15.
MTCNA MTCRE
normis
Tue Oct 15, 2019 4:03 pm
Victor, macOS has a built in tool "Automator". It's very powerful and you can create apps easily. Like this for example:
ediekeslopes
Tue Oct 15, 2019 4:21 pm
rm -rf ~/.wine/
chsh -s /bin/zsh
nano ~/.zprofile
I did the procedure and I couldn't
victorsoares
Tue Oct 15, 2019 4:28 pm
Thanks normis!
MTCNA MTCRE
TimurA
Tue Oct 15, 2019 5:28 pm
Thanks a lot Normis!
zentavr
Tue Oct 15, 2019 5:50 pm
There is also a feature which allows you to set up the icon: https://apple.stackexchange.com/questio ... tor-script
The icon could be downloaded from here: https://imgbin.com/download-png/j73uNt7L
aguntukk
Tue Oct 15, 2019 5:55 pm
Its working !!!
but impoting import address.CDB, App became hang.
After all thank you mikrotik team.
victorsoares
Anyone else having issues resizing windows? Every time I try to resize any windows on Catalina the app crashes. Am I doing something wrong or is this a real issue.
MTCNA MTCRE
TimurA
Tue Oct 15, 2019 6:15 pm
works for me.
thanks a lot!
jrpaz
Tue Oct 15, 2019 6:23 pm
Everything is working.
The only issue is importing/exporting addresss.
I bypassed that by copying the Addressses.cdb from the working 3.19 to 3.20 x64
punkaker
Tue Oct 15, 2019 6:35 pm
Winbox working, but impossible to Load the Addresses file....
TimurA
Tue Oct 15, 2019 6:37 pm
~/.wine/drive_c/users/"user name"/Application\ Data/Mikrotik/Winbox/
sbr
Wed Oct 16, 2019 12:00 am
Thank you very mush normis
Now I can shutdown my Windows 10 I Parallels
//Sten
TerminalAddict
Wed Oct 16, 2019 1:57 am
2 things:
1. This warning is annoying
https://youtu.be/NhLI0ipT9tI
Anyone know how to get rid of it?
2. automator script just does nothing :(
norg
Wed Oct 16, 2019 8:31 am
1)hold "control" click on winbox64.exe, click "open", this will add exception to your security settings
https://support.apple.com/en-us/HT202491
2)it works
normis
Wed Oct 16, 2019 8:43 am
Also, you can turn off this warning in the "System preferences" of the computer, go into "Security" section. You will have the option to allow apps from any developer, and override Winbox.
normis
Wed Oct 16, 2019 8:44 am
Make sure the "Wine Staging.app" and "winbox.exe" are exacly named like that, and placed in those paths, like you have written in your Automator script. My image shows my paths, your paths might be different.
tarikin
Wed Oct 16, 2019 9:30 am
This is a working example if you store your Addressses.cdb file in iCloud and you want to use it via new Winbox64:
cd ~/.wine/drive_c/users/"user name"/Application\ Data/Mikrotik/Winbox/
mv Addresses.cdb Addresses.cdb.bak
ln -s /Users/"user name"/Library/Mobile\ Documents/com~apple~CloudDocs/Addresses.cdb Addresses.cdb
MTCNA MTCRE MTCTCE MTCWE MTCUME MTCSE MTCIPv6E
Mikrotik Consultant status since September 2016
normis
Wed Oct 16, 2019 9:39 am
Great that you found a workaround, because on our side it has been concluded that Import problem is Catalina + Wine64 issue. We can't fix it.
tarikin
Wed Oct 16, 2019 9:59 am
No issues, all good!
Radek9112
Wed Oct 16, 2019 10:30 am
could someone answer the question what is the problem with making a Winbox application on MacOS?
There are several million developers in the world. Why do you have a problem making an application? Please give one logical example...
tarikin
Wed Oct 16, 2019 11:01 am
There are still another issues still unsolved:
1) can not paste commands to any gui or terminal window
2) can not copy nothing from gui or terminal window
* 1,2 ) but copy-paste inside the winbox app works
3) can not upload nothing via Upload button, but can Download (why?)
... Launching back my vmware vm.
p.s. Wine64 version 4.02 (via brew install wine)
normis
Wed Oct 16, 2019 11:16 am
You can do it too, Winbox has an API.
normis
Tarikin, how did you manage to install wine64 with brew?
tarikin
Wed Oct 16, 2019 11:53 am
brew install wine
/usr/local/Cellar/wine/4.0.2/bin/wine64 ~/Downloads/winbox64.exe
Downloading and installing Wine Staging now, let's try 4.17.
tarikin
Wed Oct 16, 2019 12:12 pm
Carefully followed your guide, removed wine 4.02 and installed Wine Staging (4.17)
filled the ~/.zprofile
launched winbox64 ~/Downloads/winbox64.exe
copy-paste seems to be working now (woohoo!!)
the rest is the Upload button (freezes)
[quote]0009:err:virtual:map_file_into_view failed to set PROT_EXEC on file map, noexec filesystem?
0009:err:virtual:virtual_map_section mapping 0xe20000 1000 000000000 failed[/quote]
parham
Wed Oct 16, 2019 2:01 pm
In advance, I'll apologised for anyone find this comment defensive or rude, I just ty be honest.
I never thought that one day as a Mikrotik fans I will post this, but so disappointed after over 10 years been used Mikrotiks, they did disappoint me to just relay on wine developers, they are using macOS, they are presenting MUM with macOS, every time I asked when we are going to have Native macOS winbox no answer. the time is now, guys you are the software developer also you are a vender, why in the earth you are relaying on Wines software to run winbox, just develop your own, I know there is SSH, WebFig but honestly everyone use winbox because it’s easy to use, powerful and very visible to config and troubleshoot, I have over 50 clients with over 200 Mikrotik and can't use winbox anymore. tired of using wine wrapper and wine software.
The main issue is us as a Mikrotik users trying to show off by finding the workaround, Please guys stop doing this you are all capable to finding the workaround but not realizing that every time you are finding the workaround, Mikrotik will use that to not developing the native macOS or Linux version of winbox.
Hope we see native macOS and Linux WinBox soon.
normis
Wed Oct 16, 2019 2:53 pm
You already have native Web interface. What's wrong with it? Many macOS native app will not be much different, just no browser.
TimurA
Wed Oct 16, 2019 4:02 pm
everything suits me, thanks again. CrossOver will release a new version soon, we will live even better.
mkx
Wed Oct 16, 2019 4:10 pm
For me two things:
  • with WebFig it's not possible to have more sub-windows open at the same time ... only jumping between sections. When debugging something it is very useful to have possibility to check more aspects of same problem instantaneously ...
  • and more important: GUI over MAC connectivity. I'm not aware of any alternative ... but please, enlighten me if there is one.
BR,
Metod
parham
Wed Oct 16, 2019 4:55 pm
It is nothing wrong with it, as I have mentioned, just for troubleshooting its not and never be as useful as WinBox.
With WinBox you can have lots of windows open and have see everything but with WebFig you don't have it.
I appreciate your comment and all nice job you are all doing, but after over 10 years can we have a native WinBox for macOS and Linux, Please.
Parham
parham
Wed Oct 16, 2019 5:00 pm
Is there any technical limitation for Mikrotik to create a native WinBox for macOS and Linux? If yes, then I will delete my comment, and if there is no limitation to develop the native WinBox, can we please have it.
Parham
TerminalAddict
Wed Oct 16, 2019 10:31 pm
2)it works
this works with mac apps, not with windows executables (see screenshot)
You can't do this anymore in Catalina, there is no "allow any apps" anymore.
On the plus side, I had security setting opened when I tried opening winbox, and look what magically pops up :)
so that my warning box solved .. now to figure out my automator script.
currently have an alias in shell environ
alias winbox='/Applications/Wine\ Staging.app/Contents/Resources/wine/bin/wine64 /Applications/winbox64.exe'
norg
Wed Oct 16, 2019 10:41 pm
i had this problem on macbook where I didnt have “the unarchiver” which takes exe as its file
Popup open with warning that it isnt mac os file but after that start by automator was without warrning
In automator I have exactly the same as Normis and it is working
Only problem is when you close winbox and dont wait for automator to end and start it again, it wouldnt
TerminalAddict
Wed Oct 16, 2019 10:59 pm
I have automator running with the following:
TerminalAddict
Wed Oct 16, 2019 11:04 pm
phew, finally back to where I was 3 weeks ago :)
mandrade
Thu Oct 17, 2019 2:09 pm
An "easier" method to run winbox on Catalina:
- Install Mac Brew by following the single step instruction found at: https://brew.sh/index_en
- Install wine from Mac Brew: brew install wine
- In your Mac home create a folder called winbox and put winbox64.exe there
- Test if everything works by opening a terminal and running: cd ~/winbox; wine64 ./winbox64.exe
- After that, create an Automator like the print screen below in the folder /Applications (give all the authorizations it requests on first run).
- Additionally, take your windows Addresses.CDB file and copy it like this: cp Addresses.CDB ~/.wine/drive_c/users/myuser/Application\ Data/Mikrotik/Winbox/
- Remember to change in cp command, "myuser" for your username in wine
parham
Thu Oct 17, 2019 2:35 pm
WOW, Congratulation to everyone that find the workaround and spent lots of time, you all know what, there is a very easy way once for all, to Mikrotik release the native WinBox. have you guys had a sec to think about that too.
Campano
Thu Oct 17, 2019 3:18 pm
Tks a Lot Guys!
normis
Thu Oct 17, 2019 3:46 pm
mandrade, your version is not "easier" :)
same steps: 1. install wine 2. make automator action
mandrade
Thu Oct 17, 2019 4:32 pm
I disagree,
Installation via brew not require change default X11 server ( install XQUARTZ required by wine ) and Mac brew opens a lot of new possibilities to Mac 8)
BR
normis
Thu Oct 17, 2019 4:36 pm
Xquarz no longer required by Wine. Simple installer with Next->Next.
Homebrew install doesn't add wine64 to environment, you must guess where the binary is. Can't install latest Wine.
Nothing against hombrew.
norg
Thu Oct 17, 2019 6:51 pm
On my MacBook installation of Wine asked for Xquarz (at least 2.7.7.)and wasn't able to continue
mohamads
Thu Oct 17, 2019 10:59 pm
Use this for your app icon: download/file.php?id=10814
To get address list from your windows winbox (cdb stored address list)
copy the Addresses.cdb from C:\Documents and Settings\%USERNAME%\Application Data\Mikrotik\Winbox\
Then from mac copy to : cd ~/.wine/drive_c/users/user/Application\ Data/Mikrotik/Winbox/
Change user marked in red to your actual user. Quickest way to unhide or hide files in mac use key ( CMD + SHIFT + . )
Or just move them through terminal.
TerminalAddict
Fri Oct 18, 2019 1:12 am
you are correct, no xquartz required in wine staging.
Also I'd recommend this "wine staging, automator script" as not everyone has brew setup, and brew can be daunting for some.
dschulz
Fri Oct 18, 2019 3:20 am
For those interested, there's Platypus, a free application for macOS that allows you to build native application bundles from scripts. Once you get your Wine Staging playing nicely with winbox64.exe, you can build an app bundle with a custom icon and place it in your Applications folder.
zochnetdave
Fri Oct 18, 2019 4:34 am
I am also getting an error requiring xQuartz 2.7.7 after opening Wine Staging in Installer. I see that others are claiming it is not required - any tips/tricks? TIA
normis
Fri Oct 18, 2019 8:42 am
Make sure you have the latest wine, 4.17 staging:
https://dl.winehq.org/wine-builds/macos ... g-4.17.pkg
senux1988
Fri Oct 18, 2019 3:32 pm
Hi, I edit Winbox4Mac.app. Replace Winbox.exe on Winbox64 and Wine on Wine64. App required permit in security settings, because it is not signed by a certificate.
Try download: https://webshare.cz/#/file/A72or3or35
AndrewM
Fri Oct 18, 2019 3:41 pm
Yes, xQuartz 2.7.7 + still requed. Just tried install .pkg from normis's link
antoniojailson01
Fri Oct 18, 2019 4:08 pm
here is also giving the same error does not allow to install wine
Runage7
Sat Oct 19, 2019 4:43 am
Thanks for all your help.
When the native MacOS app will be released? I’m thinking on wait and do not upgrade to Catalina until we have this version, because all of our work depends on winbox...
antoniojailson01
Sat Oct 19, 2019 4:58 am
I had to install the brew to install wine later, because pkg did not install because I did not have XQuartz 2.7.7
IvanHC4
Mon Oct 21, 2019 6:52 pm
I need help
I get the following error when executing: brew install wine /usr/local/Cellar/wine/4.0.2/bin/wine64 winbox64.exe
Error: wine64: /usr/local/Cellar/wine/4.0.2/bin/wine64:1: invalid multibyte char (UTF-8)
Any solution?
Nevon
Mon Oct 21, 2019 10:50 pm
I made that mistake to upgrade to Catalina...
Waiting.. for a real macOS app.
victorsoares
Mon Oct 21, 2019 10:59 pm
Working fine here, except for the upload/download option.
MTCNA MTCRE
hci
Long time Member
Long time Member
Mon Oct 21, 2019 11:03 pm
It would be nice if Mikrotik offered an official WineSkin, WineWrapper or somehting like that version of Winbox64. A native Mac version of Winbox would be better yet though.
tomasjanata
Tue Oct 22, 2019 1:43 am
I am on the Mac OS Catalina too and loosing of Winbox is disaster for me. I am working every day With this app and web based UI is impossible to use. Right now I have running winbox64, but Import of old addresses, upload and download is not possible. I followed full communication of this topic here but seems that nobody has solution till now. Please Mikrotik guys help us!! We need native winbox for mac OS Catalina.
Thank you so much for any help
Tomas
theprojectgroup
Tue Oct 22, 2019 10:14 am
Thx for the howto run winbox64 !
Make sure to backup "/Users/your-user-name/.wine/drive_c/users/flo/Application Data/Mikrotik" to later restore it to keep your connections...
salt
Wed Oct 23, 2019 3:47 am
Concerning Upload/Download Problem:
Seems like there is still a linked reference to the kernel32.dll in the Winbox64.
0009:err:virtual:virtual_map_section mapping 0x1840000 1000 000000000 failed
0009:fixme:seh:RtlCaptureStackBackTrace (0, 32, 0x328e30, 0x0) stub!
ACCESS VIOLATION EXCEPTION at address: ___ 7fff68357d5d
rip=___ 7fff68357d5d eflags=__ 10206
rdi=_______________0 rsi=________ 19c9010 rbp=_________ 32a790 rsp=_________ 32a790
rax=_______________0 rbx=_______________0 rcx=_______________0 rdx=_____________ 24
 r8=__________ 100a8  r9=___________ 5342 r10=_______________0 r11=fffffffffe636ff0
r12=_______________0 r13=_____________ 44 r14=________ 19c5020 r15=__________ 701ae
winbox version: 3.20
backtrace:
stack:
linked to KERNEL32!
0009:err:virtual:virtual_map_section mapping 0x1840000 9000 000000000 failed
moduleFirst failed 5
code:
c5 fc 11 07 48 83 c6 20 48 83 c7 20 48 83 ea 20
martinkaplan
Wed Oct 23, 2019 10:22 pm
This worked flawlessly.
Thanks a lot.
Boter
Wed Oct 23, 2019 11:42 pm
This actually got even simpler: https://github.com/nrlquaker/winbox-mac
If you don't want to read - just use brew.
brew cask install nrlquaker-winbox
Works flawlessly on Catalina
anatod
Thu Oct 24, 2019 2:21 am
with wine staging 4.18 work import/export options... https://dl.winehq.org/wine-builds/macosx/download.html
normis
Thu Oct 24, 2019 7:46 am
Yes, it looks like all file operations are fixed in Wine Staging 4.18
Thanks for pointing it out, Anatod!
Nevon
Thu Oct 24, 2019 9:49 am
How do you import addresses?... where?
hci
Long time Member
Long time Member
Fri Oct 25, 2019 3:43 am
Will homebrew modify my mac os system files etc? Is it simple to remove homebrew and undo all it did? Just do not want to mess up my mac that usually 'just works'.
normis
Fri Oct 25, 2019 9:13 am
homebrew is a must have tool for any mac user.
that being said, you can just not use homebrew - install this and nothing else https://dl.winehq.org/wine-builds/macos ... g-4.18.pkg
yag
Sat Oct 26, 2019 10:14 am
Normis, what about netinstall64? )
Nevon
Sat Oct 26, 2019 10:25 pm
Someone who can help me. Updated my own CCR1009 to V7 and could connect 3 times with my wine winbox app.. now when I try to connect the window disapper..
FernandaAdhipramana
Mon Oct 28, 2019 5:46 pm
rm -rf ~/.wine/
chsh -s /bin/zsh
nano ~/.zprofile
Thanks dude, its working
eset
Tue Oct 29, 2019 12:03 pm
It would be great if that could work without fuckin up my CPU in Iterm2. Also previous wine was working just on 1-click on winbox.exe file. This staging won't work like that. In fact when developers will create winbox for macOS ?
jemineye
Sun Nov 03, 2019 1:23 am
dschulz, I tried Platypus with variables like what you used but it's not taking them. Are there any other settings I need to adjust? I see you're referencing the wine64 executable as the script type and the winbox64.exe as the path to the script. That's what I tried and it isn't liking it.
andrewlp
Sun Nov 03, 2019 1:50 pm
All I can say is thanks so much for compiling into 64bit!
Is the 64bit version full featured and stable, or are we expecting any issues?
PS. I turns out it is actually possible to run 32bit code in Catalina, just requires some nvram arguments and copying the 32bit libraries over, but this is much more elegant
http://netkas.org/?p=1491
normis
Tue Nov 05, 2019 8:41 am
64bit Winbox is just as feature full as the 32bit version. All features the same and runs with newest "Wine Staging" in macOS, also runs on other OS.
eset
Fri Nov 08, 2019 12:35 pm
I agree. @mandrade your solution isn't accurate but I disagree that homebrew doesn't add wine64. It does.
cd /usr/local/Cellar/wine/4.0.2/bin/ && ls |grep wine64
wine64*
wine64-preloader*
eset
Fri Nov 08, 2019 1:10 pm
I've done it differently, not using staging but just wine64 from 4.0.2 and works.
But Automator doesn't run the winbox
export PATH="/usr/local/Cellar/wine/4.0.2/bin:$PATH"
wine64 $HOME/.winbox/winbox64.exe
zmckenzie
Mon Nov 11, 2019 6:26 pm
1) Thank you @Normis. This is a big help
2) For those having a tough time with Automator, there is an easier way. 1) follow the steps Normis outlined earlier in thread. 2) create a text file with the following commands, and name winbox.sh (replace directory with correct directory for your own system) 3) Right click new winbox.sh file and Open With terminal.app. If you save this as 'always open with', then you now have a shortcut that will always open up the terminal window, and winbox right after with just a click of the mouse.
#!/bin/bash
wine64 ~/Desktop/windows_apps/winbox64.exe
32768
Thu Nov 14, 2019 9:52 pm
Can somebody explain me how to install winehq-staging-4.19.pkg without XQuarz?
When i run the Installer it quits right at the start claiming the need of XQuarz.
Any hints appreciated.
// 32768
eles
Mon Nov 18, 2019 12:44 pm
Just tried,
wine 4.0.2 stable with 64bit support works with Normis's procedure too (no additional XQuartz install required, just press next until it installs)
I had no luck running it with wine-staging (4.20) because of some error.
MTCNA #1905NA3991
MTCRE #1909RE5178
hbml
Mon Nov 18, 2019 1:53 pm
Hello, this file show me virus in Bitdefender
Gen:Variant.Fugrafa.10146
Cesta: /Users/user/Library/Application Support/com.mikrotik.winbox_3.20.2/dosdevices/z:/Applications/Wine Staging.app/Contents/Resources/wine/lib/wine/secedit.exe
The same problem with WineHQ 4.19 and 4.20
something like this in version 4.20:
Gen:Variant.Ursu.652045
Cesta: /Users/user/.wine/dosdevices/z:/System/Volumes/Data/Users/user/.Trash/Wine Staging.app/Contents/Resources/wine/lib/wine/netsh.exe
and in version 4.19:
Way: /Applications/Wine Staging.app/Contents/Resources/wine/lib/wine/ngen.exe
Gen:Variant.Fugrafa.10148
Way: /Applications/Wine Staging.app/Contents/Resources/wine/lib/wine/rpcss.exe
Any Help?
Thank you
32768
Mon Nov 18, 2019 9:59 pm
Just tried,
Please explain what you mean with "just press next ..." - I don't have a "Next" Button ... the pkg Installer quits right after the start claiming the need of XQuarz.
So how can i skip that if the installer right quits?!?
Did i missed something?
Unintentional
Tue Nov 19, 2019 7:30 am
Just tried,
I also have an issue with 4.20 Staging. 4.19 (and prior versions) run fine though. Anyone got 4.20 working?
WeWiNet
Wed Nov 20, 2019 1:01 pm
Isn't it ridiculous that we need to discuss in a thread how to make the basic and mandatory Mikrotik configuration
tool available for Mac users?
Imagine how much time Mikrotik resellers/users/promoters spent, which they don't spent on selling/promoting Mikrotik products!!!
There should be a sticky forum entry about building Winbox on Catalina with real step by step instructions for the dummy!!!.
Please provide a sticky thread with instructions...this should be not much effort on Mtik side as you always say its simple!
And then community can use easily...
WeWiNet
MTCNA
hapac2, map, hap-lite, ltap-mini, RB4011 :-) !!!
normis
Wed Nov 20, 2019 1:02 pm
32768
Wed Nov 20, 2019 9:44 pm
Why thread if there is the manual?
https://help.mikrotik.com/docs/display/ ... OSCatalina
Because the instruction doens't work.
When i start the Installer it quits right after lunch claiming the need of XQuarz 2.7.7.
And you wrote before that there is no need to install XQuarz and i don't want it on my clean catalina install.
So, please explain me how i can install it ;-)
Users browsing this forum: MSN [Bot] and 42 guests
