jimint
Best VPN for Mikrotik Router
Tue Oct 08, 2019 8:35 am
Hello
Please can someone tell me about which is the best VPN company (IPVanish-NordVPN-ExpressVPN etc.) for mikrotik setup?
erlinden
Re: Best VPN for Mikrotik Router
Tue Oct 08, 2019 12:22 pm
What is your definition of "the best"?
Lifz
Tue Oct 08, 2019 12:44 pm
BestVPN is one you make yourself, host CHR somewhere and use native Mikrotik protocols (EoIP, IPIP, etc.)
Generally avoid TCP based protocols (SSTP, OpenVPN) for performance reasons (single TCP connection), always prefer UDP ones (PPTP, L2TP,...).
Obviously it all depends on what you are trying to do.
xvo
Long time Member
Long time Member
Tue Oct 08, 2019 12:47 pm
True.
IPANetEngineer
Trainer
Trainer
Tue Oct 08, 2019 4:37 pm
This often depends on what the clients will be...
Phones, Laptops, servers, firewalls??
You also need to consider the type of Internet connection the clients will be coming from - in some cases, TCP/443 behind NAT is all you are allowed to use.
UDP based VPNs are great if they meet the requirements listed above, if not, then select a VPN for connectivity first, then performance.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
pe1chl
Tue Oct 08, 2019 6:05 pm
I think he is (like most new users) not looking for a VPN in the traditional meaning (to make a virtual network between two routers he is both managing), but the "new meaning" of "route all my internet traffic to some more-or-less trusted party who will route it to internet, instead of doing that directly via my ISP".
This really only makes sense when done from endpoint devices (like a PC or Phone), but for some reason people want to do that from their router too.
Steveocee
Tue Oct 08, 2019 6:59 pm
If they support L2TP and will happily give you a username, password and IPSEC key then they should be fine.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
pe1chl
Tue Oct 08, 2019 7:13 pm
Yeah, but that is less and less popular for that kind of service. They move towards IKEv2, OpenVPN, Wireguard etc.
IPANetEngineer
Trainer
Trainer
Tue Oct 08, 2019 8:39 pm
Now that OpenVPN has UDP support in ROSv7, I expect we'll see a large migration to that once ROSv7 is prod and stable.
We've scaled OpenVPN to more than 100,000 clients with MikroTik for IoT solutions....it works really well
Sob
Tue Oct 08, 2019 9:08 pm
I wouldn't celebrate yet, there's udp in v7, but it wasn't the only missing feature. So it's great step for own use, but not much changed for interoperability with someone else's service using standard OpenVPN.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
jaytcsd
Thu Oct 10, 2019 7:05 am
Since v7 and Spinrite 6.1 seem to be a long way off, what is a good secure Mikrotik to Mikrotik VPN that also lets road warriors in, or are we talking 2 different situations?
thanks
pe1chl
Thu Oct 10, 2019 11:30 am
For roadwarrior clients I normally use L2TP/IPsec.
A single IPsec PSK is shared between all clients and each client has a username/password.
Of course when you want you can add the extra complexity of using certificates, and/or maybe IKEv2.
IPANetEngineer
Trainer
Trainer
Thu Oct 10, 2019 4:10 pm
We've been able to interop with non-MikroTik OpenVPN linux builds. It takes a little work but is completely doable.
pe1chl
Thu Oct 10, 2019 4:25 pm
The question is more: is it interoperable with existing OpenVPN server deployments as they are commonly made, without server-side changes.
Until then, there will be issues when connecting to servers that are outside your own control for management/configuration.
It would be best when MikroTik just used the existing OpenVPN code, as far as that is possible w.r.t. licensing.
Users browsing this forum: Google [Bot] and 90 guests
