MUM Europe 2020
abdalnoor
VPN PPTP
Tue Oct 08, 2019 3:15 pm
i need to config PPTP server using my router board 952 and when i connect using vpn from my pc windows 10 and can't reach my local network e.g my dvr 192.168.7.10 and can only access the routerboard , and below is the export from my router board
add arp=proxy-arp name="BR - DHCP" protocol-mode=none
add name="BR - MGM" protocol-mode=none
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=\
    10.25.240.170 name="01 - Main"
set [ find default-name=ether2 ] advertise=\
    192.168.7.10 name="02 - DVR"
set [ find default-name=ether3 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="03 - "
set [ find default-name=ether4 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="04 - "
set [ find default-name=ether5 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="05 - "
/interface pppoe-client
add add-default-route=yes disabled=no interface="BR - MGM" keepalive-timeout=\
    disabled name=pppoe-out1 password=nnn user=n@n
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=profile1 \
    supplicant-identity="" wpa-pre-shared-key=12345678 wpa2-pre-shared-key=\
    12345678
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    disabled=no hide-ssid=yes mode=ap-bridge name="wlan1 - 2G" \
    security-profile=profile1 ssid=MikroTik2G
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
    disabled=no hide-ssid=yes mode=ap-bridge name="wlan2 - 5G" \
    security-profile=profile1 ssid=MikroTik5G
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.7.100-192.168.7.254
add name="VPN Pool" ranges=192.168.7.50-192.168.7.60
add address-pool=dhcp_pool0 disabled=no interface="BR - DHCP" name=dhcp1
/ppp profile
add dns-server=8.8.8.8 local-address=192.168.7.1 name=profile1 remote-address=\
    "VPN Pool"
add bridge="BR - DHCP" hw=no interface="02 - DVR"
add bridge="BR - DHCP" hw=no interface="03 - "
add bridge="BR - DHCP" hw=no interface="04 - "
add bridge="BR - DHCP" hw=no interface="05 - "
add bridge="BR - DHCP" interface="wlan1 - 2G"
add bridge="BR - DHCP" interface="wlan2 - 5G"
add bridge="BR - MGM" hw=no interface="01 - Main"
/interface pptp-server server
set authentication=mschap2 enabled=yes
add address=10.25.240.171/24 interface="01 - Main" network=10.25.240.0
add address=192.168.7.1/24 interface="BR - DHCP" network=192.168.7.0
add address=192.168.7.0/24 dns-server=109.224.14.2,109.224.14.3 gateway=\
    192.168.7.1
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input protocol=gre
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=R7 passthrough=yes \
    src-address=192.168.7.0/24
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=\
    192.168.7.0/24
add distance=1 gateway=pppoe-out1 routing-mark=R7
add distance=1 dst-address=10.25.240.0/24 gateway="BR - MGM" routing-mark=R7
add distance=1 dst-address=192.168.7.0/24 gateway="BR - DHCP" routing-mark=R7
add distance=1 gateway=10.25.240.1
add distance=1 dst-address=216.239.35.12/32 gateway=pppoe-out1
/ppp secret
add name=abdulnoor password=11111111 profile=profile1
Reason: Please post configs/code in [code] blocks to save peoples scroll wheels
Sob
Re: VPN PPTP  [SOLVED]
Tue Oct 08, 2019 9:33 pm
It's because all response packets from 192.168.7.0/24 get routing mark R7 and they are routed back to "BR - DHCP" interface instead of to VPN client. At first sight the whole part with routing marks seems completely useless, so unless you have some good reason to have it, just get rid of it and everything should work.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Zacharias
Re: VPN PPTP
Tue Oct 08, 2019 10:31 pm
Sob is right... why that mangle rule and all those routing marks?
abdalnoor
Re: VPN PPTP
Wed Oct 09, 2019 11:05 am
thanks for your replay it's solved my issue , and for these mangles i used the pppoe client and route my local traffic to this pppoe and when i disabled these static routes there no internet but i can access my DVR , so i cannot get rid of them
Users browsing this forum: eworm, ferastemimi, jebz, jindranix and 84 guests
