MUM Europe 2020
abis
IPSec/L2TP
Tue Oct 08, 2019 3:47 pm
Hello, I found that post https://serverfault.com/questions/45138 ... ipsec-lt2p and I want to increase my ports input security. At this moment i have that rules for IPSec/L2TP
chain=input action=accept protocol=udp in-interface=ether1 dst-port=500,1701,4500 log=no log-prefix=""
chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
chain=input action=accept protocol=ipsec-ah log=no log-prefix=""
But in post In post I read "Port 1701 is used by the L2TP Server, but connections should not be allowed inbound to it from outside. There is a special firewall rule to allow only IPSEC secured traffic inbound on this port."
The question is: How I can translate this rule in MikroTik?
iptables -A INPUT -i $EXT_NIC -p udp -m policy --dir in --pol ipsec -m udp --dport 1701 -j ACCEPT
Thank you guys!
Image Image
IPANetEngineer
Trainer
Trainer
Re: IPSec/L2TP
Tue Oct 08, 2019 8:22 pm
You'll probably need a bit of trial and error with this one but I think this is a fairly close translation into RouterOS from iptables
add action=accept chain=input dst-port=1701 in-interface=ether1 protocol=udp src-port=500
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Sob
Re: IPSec/L2TP
Tue Oct 08, 2019 9:13 pm
What you're looking for is ipsec-policy matcher:
add chain=input action=accept protocol=udp dst-port=1701 ipsec-policy=in,ipsec
And remove 1701 from the other rule, because that would allow also unencrypted L2TP.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
abis
Re: IPSec/L2TP
Wed Oct 09, 2019 11:01 am
Thank you for reply! I'll start to test yours suggestions.
Great day!
Image Image
Users browsing this forum: No registered users and 5 guests
