MUM Europe 2020
mvalsasna
RB953GS-5HnT-RP+R11e-LTE reliability issues
Tue Oct 08, 2019 4:15 pm
Hi
we are using R11e-LTE on RB953GS-5HnT-RP on 100+ units, and several units exhibit reliability issues:
* R11e-LTE not recognized by ROS sistematically
* R11e-LTE not recognized by ROS on warm reboot, but works after cold reboot
* R11e-LTE not recognized by ROS on warm reboot, but works after cold reboot with power off for a long time (~1h)
* R11e-LTE recognized by ROS at boot, but when it connects to the 4G network the interface lte1 disappears from ROS
* R11e-LTE recognized by ROS at boot, operates normally for several days, then the interface lte1 disappears from ROS, is not recognized after repeated warm reboots. a cold reboot fixes the issue
* R11e-LTE recognized by ROS at boot, operates normally for several days, then the interface lte1 disappears from ROS, is not recognized after repeated warm reboots. a cold reboot with power off for 1h does not fix the issue. then the interface reappears after days of trying with warm reboots.
issues seem to be dependent on the specific combination of R11e-LTE + RB953GS-5HnT-RP + SIM card/network operator, changing one element sometimes change the behavior
we're using routeros 6.45.5 and MikroTik_CP_2.160.000_v012 firmware on the R11e-LTE
Mikrotik support suggested setting
/system routerboard settings set boot-delay=9s init-delay=9s
, and this helped in a few cases, but did not solve the issue.
anybody is having similar issues? any suggestions?
can you suggest a LTE card that works well on RB953GS-5HnT-RP (tested on ~100 units) and is not EOL?
thank you
MAtteo
robpeng
Re: RB953GS-5HnT-RP+R11e-LTE reliability issues
Tue Oct 08, 2019 11:31 pm
Hey,
Have you tried
/system routerboard usb set type=mini-PCIe
I have seen issues before with my RBM11G + R11e-LTE and this fixed it, AFAIK this tells the board to supply the PCI with the correct power VS usb
SiB
Thu Oct 10, 2019 5:07 am
the EP-06 is good working on many RB. I test it only at RBM33G. At forum is post with wAP R ac in howto way.
Quectel EP06-E and wAP R ac (RBwAPGR-5HacD2HnD) = viewtopic.php?f=3&t=150368
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on 26-27 march 2020
Users browsing this forum: Bing [Bot], Google [Bot] and 110 guests
