MUM Europe 2020
pe1chl
OpenVPN .ovpn
Tue Oct 08, 2019 9:38 pm
- OpenVPN UDP protocol support
OpenVPN should be able to read (import) standard OpenVPN .ovpn files that work with the standard client, and that include
- remote server
- protocol specification
- compression options
- authentication parameters
- client certificate
- options like passtos, explicit-exit-notify, reneg-sec, etc. preferably every option of the open software
It is no problem when the file is converted to MikroTik-specific config an certificate storage
Cha0s
Forum Veteran
Forum Veteran
Re: OpenVPN .ovpn
Wed Oct 09, 2019 11:55 pm
+1 :)
Specialised
Re: OpenVPN .ovpn
Thu Oct 10, 2019 9:21 am
+34234892734 implement immediately! :?
Sob
Re: OpenVPN .ovpn
Thu Oct 10, 2019 4:21 pm
I'd rather implement functionality of all those options first, and then I'd think about config importer. ;)
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
pe1chl
Re: OpenVPN .ovpn
Thu Oct 10, 2019 4:22 pm
I would hope that at some time MikroTik find some way to replace the entire OpenVPN thing with a recent version of the opensource implementation....
That will solve a lot of issues, at least until OpenVPN development further continues and becomes incompatible again.
Sob
Re: OpenVPN .ovpn
Thu Oct 10, 2019 5:18 pm
They could have done that in last 10+ years. And they still implemented first tcp, and now (after finding suicide-proof developers) even udp themselves. So my guess would be probably not for official OpenVPN.
Users browsing this forum: Bing [Bot], C0ReDuMP, dalami, h0m3, McSee, robertkjonesjr and 105 guests
