firebat
Graphing OID values on link
Thu Apr 19, 2007 9:17 am
I have a link that displays the RSSI value for an AP and CPE obtained via SNMP. Is there a way to have DUDE graph this as it does with [Interface.OutBitRate] and [Interface.InBitRate] when you hover over the values on the link?
rbmota
Fri Apr 20, 2007 11:36 am
Hi
I'm doing something similar with uptimes, cpu usage, and other similar stuff.
What I did was to create a Data Source (in the Charts menu), of type SNMP OID, and then enter the OID of the target device.
The create a Chart, add this newly created Data Source.
You can also make some more complex things, by defining functions and other neat stuff - I'm using to graph the number of PPP interfaces that are UP in any given moment.
BR
Ricardo Mota
gmsmstr
Trainer
Trainer
Re: Graphing OID values on link
Wed Dec 12, 2007 1:56 am
This works, but what if you have multiple APs etc. How do you get it for each? Or do you ahve to creat charts for each : ( Is there a way to add this to the probes to have it show up?
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
Users browsing this forum: No registered users and 11 guests
