BubaKukin
Format of Option 82
Sat Oct 12, 2019 7:10 pm
The contents of Option82 are not documented.
Yes, I determined what it consists of.
For example, a packet arrives through ethernet port 15 (which interface name is "15") of vlan 101 on a switch SW-1
In this case:
agent.remote-id = "15"
agent.circuit-id = "SW-1 eth 0/15:101"
It is too arduous.
Is it possible to form the Option82 at will?
For example...
agent.remote-id - <device name> or <device IP address on vlan>
agent.circuit-id - <port number> or <descriptive interface name>
I know if switch used as dhcp-relay the opthion 82 may be changed with:
remote-id = variable string
cirquit-id = MAC of vlan (cna't be changed)
Тhis also does not fit. No port information.
rdelacruz
Re: Format of Option 82
Tue Jun 30, 2020 10:36 pm
I am having the same issue? Have you resolved this problem?
Users browsing this forum: ByzdeJr, erlinden, kurlandaniel, plisken, unps, Znevna and 103 guests
